Snow tire advice
Discussion in 'Model 3' started by Omniver, Jul 5, 2018.
  1. Omniver
    Omniver Member
    Boston
    Expecting (hoping) for my non-P AWD to arrive in the next few months - just before Massachusetts winter. Opted for 19” sport wheels, figure I should plan to get some snows - would like to not pay the price for the Tesla set; any advice on options? Never bought snows before.
  2. dgpcolorado
    dgpcolorado high altitude member
    The Western Slope, Colorado
    I've been very pleased with my Michelin X-Ice snow tires. They get me up my long, steep, curved driveway in both snow and ice and I have a RWD car. I've pushed through eight inches of snow without difficulty. I expect that with AWD they would be terrific. FWIW.
  3. Sparky
    Sparky Member
    Glendale,CA
    Agree. I prefer the Michelin X-Ice. Quieter than the Bridgestone Blizzaks and very small increase in Wh/mi compared to the Goodyear All-seasons.
    @Omniver : Try TireRack. It looks like they offer the Michelins and some pretty inexpensive 18's.
  4. dgpcolorado
    Now that you mention it, I'm always surprised with how quiet my Michelin snow tires are compared to my regular Goodyear tires when I make the switch.
  5. TheShark
    TheShark Member
    Algonquin, IL
    +1 on the X-ICE. I ran them this winter on my model 3 (18” Aeros minus the hubcaps) in Chicago. We took delivery in January so we got a decent bit of weather after that. They worked outstanding in all of the conditions we faced this winter.
  6. Snow Drift
    Snow Drift Slip Start: [Activated]
    Long Island
    #6 Snow Drift, Jul 5, 2018
    I run X-Ice on my STI, and Blizzaks on the wife's XV Crosstrek Hybrid. Both are good, but the X-Ice are a bit better performance in the dry.
    The best are Michelin Pilot Alpin PA4 or the Pirelli Winter Sottozero; for performance snow tires.
    Also, since you got the 19's you should really downsize to 18" rims and narrower rubber for winter. 19" and 235 is really big/wide for the snow. I had the same issue with my STI (19" & 245 wide), so I had to spend $$$$ on new rims/tpms/tires. That's why we just ordered the 18" Aero rims and will get 225 wide snow tires.
    X-Ice:
  7. Ookies
    Ookies Member
    Chicago
    The king of snow tires - nokian hakkapeliitta r2
  8. Nate977p
    Nate977p Member
    Boston
    Nokian Hakkas. They are amazing and I have driven on many. Where are you in MA? There is a good amount of dealers around.
  9. chowfun
    chowfun Member
    NY
    Do they sell 225 with x-ice? I can't find them on tire rack. Should I also add the TPMS? $260 seems kinda steep.
  10. felixculpas
    felixculpas Member
    Ontario, Canada
    The new Hakka R3's look interesting. Youtube
  11. Nate977p
    Nate977p Member
    Boston
    Nokians are weird. Not as mass market l, but the best out their. Go to their site direct for sizing.
  12. Thomas Edison
    Thomas Edison Active Member
    Portland-ish
  13. turbo2pointo
    turbo2pointo New Member
    Seattle
    Do you guys buy tire from tire rack and ship to a local to swap the tires on existing rims?
    If so, they don't need to get new TPMS or program the existing again?
    And when summer time comes, you pay to swap them back on?
  14. jaguar36
    jaguar36 Active Member
    NJ
    I always just get the snows on a separate set of wheels so I can swap them myself. Only takes half an hour to swap a set so its worth it to me to not have the hassle of having to take it somewhere.
  15. Snow Drift
    Long Island
    Yes, my picture above are 225/45/18. You may need to just search for the tire and not by car as TR will default to 235 for the M3.
    If you buy new rims you will need TPMS sensors and a way to upload the radio code to the car. Just get Tesla to do it. About $100 usually.
    Yea ship to store or your house and drive them over. If you use the stock rims you don’t need to change the codes. Then in the spring just change to summer tires.
  16. TheShark
    TheShark Member
    Algonquin, IL
    if you're going to keep the car for any amount of time I'd highly recommend getting the second set of rims. It's much easier and quicker to deal with. While I may be over reacting (I'm not a tire expert) i'd rather have the tires seated once on the rim rather than pull them on and off the rim twice a year.
    As for TPMS, the standard TPMS modules from tire rack work just fine. My car recognizes the new TPMS sensors and tire pressures are up an running in a couple minutes of driving. No action from Tesla required. The other plus is that the swap from winters to summers and vice versa is pretty much your tire rotation for the year unless you're driving a lot.
    As a side note I run my winter tires on the aero wheels. I figure if I really need the range boost that the hub caps are supposed to give it's going to be in the dead of winter when its frigid out (and i don't skimp on the heat) and i have winter tires running in the snow... That being said during the winter this year I still averaged ~270-280 wh/mi which i can live with since i had the heat at 68-72 and the seat heaters on then entire time and I precondition the car almost every time i go out to it. The hub caps just sat in my garage collecting dust.
  17. Ookies
    Ookies Member
    Chicago
    FWIW - I bought my hakka r2 on ebay through a dealer; Got 4 tires for ~$530; will switch my current aero wheels w/ the winter tires; and buy me a set of TST 18in or another aftermarket wheel...
  18. SageBrush
    SageBrush 2018: Drain the Sewer
    New Mexico
    Fair price
    The best I found from an onlilne store was $640 per set, although that included S&H and a road hazard warranty.
  19. JeffK
    JeffK Well-Known Member
    Indianapolis
    What about snow tires for the performance version with the larger rotors?
  20. Snow Drift
    Long Island
    What about it? I would not use the 20s. Use the stock 18s that fit or wait for a shop to test fit other styles. Then, get narrower than stock size snow tires. Wait for Unplugged or TireRack to test fit sizes.
