Snowed in
Discussion in 'Model S: Battery & Charging' started by mrElbe, Jan 27, 2016.
  1. mrElbe
    mrElbe Active Member
    Stouffville, ON Canada
    Went yesterday morning to the Strasburg WVA supercharger behind the Denny's. That arrangement is not conducive to snow clearing.
  2. AudubonB
    AudubonB Investing is fun!
    I'm glad you were able to charge, given that set-up. This surely would have been discussed elsewhere, but are those photos deceptive or are the stalls placed at 45º or so to the lot's apparent orientation? If so, do you know why?
  3. mrElbe
    Yes, the stalls are angle parking. Most likely due to the narrow space between the building and the fence.
  4. Max*
    Max* Charging
    NoVa
    That's not WVA, just VA.
    And someone already commented in the SpC thread, and Tesla responded that they're going to send someone out to clear the snow.
  5. Cyclone
    Cyclone Cyclonic Member ((.oO))
    Charlotte, NC
    I'm surprised that Tesla just didn't spend incrementally more per charger stall (I know it adds up) to make the cord longer for situations like this. Surely someone at some point realized that snow plows may build banks up by the chargers and not let the cars get close enough in to charge. There have been threads before that some had to dig a bit so they can get their cars close enough to charge. I get that in each case, Tesla was notified and promptly sent someone to clean it up, but that's reactionary and I would have have thought Tesla would have the foresight to plan ahead for this.
  6. HankLloydRight
    HankLloydRight No Roads
    Connecticut
    With that much power available at the SC, why not put in under pavement radiant heating?
  7. AudubonB
    That would sure make a skating rink icy mess.
  8. taurusking
    taurusking Member
    East Texas
    I like this ^^^:wink:
  9. Electric700
    Electric700 Active Member
    Florida, United States
  10. mknox
    mknox Well-Known Member
    Toronto, ON
    I had heard that Tesla didn't put pull-in stalls in northern areas for this exact reason. I wonder what happened here?
  11. CTemp222
    CTemp222 Member
    Chicago
    What do you define as Northern? I live in Chicago and the stalls at the local supercharger are pull in stalls.
  12. AudubonB
    For Hank, Taurus and E700, I'll post again: where do you think that snow melt would go? Away?
    Nope.
  13. andrewket
    andrewket Well-Known Member
    If you can put in adequate drainage, it would work. But that would add expense, and snow to this extreme in VA is uncommon and not worth it. It's probably cheaper to add a canopy with radiant heat with gutters, down spouts into a run-off, etc. in areas where snow to this extreme is common.
  14. ohmman
    ohmman Maximum Plaid Member
    North Bay, CA
    In answer to your question about the angled spaces, Audie, yes - they are angled.
    I have been viewing a good number of Supercharger build threads while trying to populate my trailer-friendly Supercharger thread/wiki. I've run across a few that are angle-in. I don't know how much of the decision about back-in spots has to do with the cost of ripping up the asphalt and how much has to do with the potential for snow. In many cases, there is one pull-through spot which is on a corner section of a curb, and the rest are back-in.
    Obviously if the MX is intended to pull any kind of travel trailer, having only back-in Supercharger spaces is going to be problematic or at least inconvenient.
  15. mknox
    Toronto, ON
    Anywhere they get significant snow in the winter. Apparently I am wrong, or else Tesla has changed their strategy. I've been to Aurora, Country Club Hills and Highland Park in the Chicago area and they were all back in stalls as far as I recall, although Aurora is one of those "temporary" style sites with one side back in and the other side pull in. The Superchargers are normally off of the driving surface making snow clearing easier.
  16. Cottonwood
    Colorado
    Yes, it is all over the map. For example, Cheyenne, WY, has drive-in, angled stalls. Take a look at this link for pictures while under construction: Cheyenne, WY Supercharger - Page 5
    Here is one of those pictures from Cheyenne:
  17. HankLloydRight
    Connecticut
    Snow melt=water. What happens when it rains?
    Small troughs that run parallel to the stalls to drain the water away. Seems like a pretty simple problem to solve.
  18. widodh
    widodh Model S 85 and 100D
    Venlo, NL
    This happened to me in Sweden and Norway as well last winter. Multiple SuperCharger sites were snowed in. Sometimes I had to ride backwards up into a hill of snow to be able to plug in.
  19. AudubonB
    Aah, but you're changing the situation (Hank #17). If you try to melt snow when it wants to stay snow, then as soon as that snowmelt flows away from the heated pavement, it will ice up again. Extending that heated zone all the way to a drain, and it will fill and then freeze the drain. Extend the heating into the drain.....¿didn't someone say something about "low cost"?
  20. HankLloydRight
    Connecticut
