It did for me
Try this: Put both exterior and interior temperature at 30 °F and calculate. Now change both exterior and interior temperature to 70 °F and calculate. Do you see a difference in energy use? I do not.
It did for me
Given in this case, it only went 5km after 0, it's definitely not dependable. Other reviewers have been able to go further than that.I've been concerned over the number of posts along the lines of 'oh hey! you have at least 20 more miles after the battery says it's out'. People need to NOT count on that.
Were you looking at "rated range" (number under the speedometer) or "projected range" (number on the energy screen)? The "rated range" number is not dependable because it does not vary with conditions, while the "projected range" does. Like others have said, Tesla really should make the projected range number available on the speedometer display.The rated range was still above the target but we noticed that the trip meter average energy usage was quite a bit different than the 50km projection average usage so we started to get frustrated & distrust all the numbers being shown.
The other predictive stuff people are suggesting would be nice, but having the projected range on the dash is already a good first step.
Ok so why would Spurkey only get about 3 miles past zero when others (Broder) have gone further? I find this information very important if I should every find myself cutting it too close. Would I stop immediately at the nearest 110 outlet when range approached zero or would I drive a few miles to reach a better/faster charging point. There's a big difference between 3 miles of "reserve" and 19-20.
Good catch, I see no change using those numbers. Now that I've thought about it, I wonder how it calculates the energy required for cabin heating - how well does the calculator estimate how much cabin heat the car loses over the trip, thus approximating how many times/how much energy the cabin heater expends correcting the temperature delta between the exterior & the interior.Put both exterior and interior temperature at 30 °F and calculate. Now change both exterior and interior temperature to 70 °F and calculate. Do you see a difference in energy use?
2. If that is unattainable, display a range that is at best realistic, and often pessimistic. I recommend 2/3 of EPA range, which would have been 256km in your case and clearly indicated that you could not make the trip.
The Model S is 480 km Ideal or 424 km Rated. Standard Mode charges to 90% or 382 km Rated.
So that display is a full Standard Mode charge with the display set to Rated.
This.
I agree that "zero" range should equal zero miles remaining but remember most (?all) ICE vehicles have significant remaining range when the low fuel warining light comes on.
