So many rattles one after another - FINALLY all gone
Discussion in 'Canada' started by setipoo, Aug 29, 2017.
Tags:
  1. setipoo
    setipoo Breaker of Chains and Mother of Dragons
    Ontario, Canada
    Toronto Lawrence SC's service is always excellent and above expectation. Unfortunately, the car is not. Even a tiny rattle becomes irritating when all you want is a quiet ride.
    Kudos to the guys for finally fixing my endless rattles:
    front door right
    B pillar right
    C pillar right
    rear door left
    Now the ride is 100% quiet and makes the S truly spectacular.
    GOTTA LOVE THE CAR!!!!
  2. DriveMe
    DriveMe Member
    NE OH
    So what exactly did they do to fix it? Did they explain?
  3. Struja
    Struja "Fanboy"
    Toronto, Canada
    I had a squeak which driving me nuts but a quick meeting with @mrElbe (at a Gas Station) of all places and I've enjoyed the silence ever since!!!
    I'm glad you've got your "serenity now"!!!!
  4. PLUS EV
    PLUS EV Running on Empty
    Seattle
    I've had a helluva time with rattles in this car and unfortunately have not been able to get many of them fixed. The Seattle Service Center has definitely been sub-par in this regard.
  5. Phillip L
    Phillip L Gas Passer
    Owen Sound, Ontario, Canada
    Maybe they just closed the vent :cool:. Mine was rattling just to the right of the centre console screen and would stop when I pushed in below the vent. Then I realized just closing the vent stopped the rattle. I wonder if rattles are so noticeable because the car is so quiet at low speeds?
  6. setipoo
    Ontario, Canada
    Concern: Customer states there is a rattle from the B pillar area when going over bumps,
    video can be provided from drive tech:
    Pay Type: Warranty
    Corrections: Interior NVH General Diagnosis
    found wiring connector that runs behind b pillar to be rattling ,secured connector. found
    rattle from left rear door panel as well , replaced door panel clips and installed insulation
    tape. road tested
    Concern: Customer states: When driving over a speed bump (slow or fast), there is a rattle on
    the rear trunk area, that goes up and then down.
    Pay Type: Warranty
    Corrections: Spring and Damper Assembly - Rear - LH
    Replaced left and right side spring and damper assemblies. Test drove vehicle to verify
    repair
    Part Quantity
    REAR COIL SPRING MODULE S2 (1015620-
    01-C)
    Parts Replaced or Added
    Corrections: Spring and Damper Assembly - Rear - RH
    repair
    Part Quantity
  7. setipoo
    Ontario, Canada
    Concern: Customer states: Front driver side door panel rattles when closing
    Pay Type: Warranty
    Corrections: Panel - Door Trim - Front - RH
    Removed passenger front door panel and replaced all clips.
    Part Quantity
    CLIP, HEART FLEX W WSHR 70 LBS
    RETENTION (1025401-00-A)
    9
    Corrections: Panel - Door Trim - Front - LH
    Removed door panel and replaced all clips.
    Part Quantity
  8. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    My car has had a minor rattle in or near the rear left door since delivery. I haven't raised it with Tesla because I figured I'd wait and see if something else popped up, and nothing has.
