Got my Model X on Wednesday, and it is going back to the service center on Tuesday so they can investigate two issues I'm having:
1) The biggest issue is that one of the FWDs doesn't always open all the way, even if nothing is blocking it. For example, in my garage, there is PLENTY of room around the car. When I went to open the door from the key fob, the door only opened slightly and then beeped as if there is some kind of obstruction. I had to bend down underneath the door and manually override it using the little lever on the inside of the doorframe. I was able to raise it fully using the little lever, and when the door is fully open there is nothing near the door. When I pulled the car forward a few feet, the door opened without any issues, even though it was even closer to our shelves. The next morning, when I went to use the car (in the same spot as the night before), the doors would only open partially, even though they had opened fully the night before. Is anyone else having this same issue? Was it resolved? I've attached two pictures - one showing the door where it was getting stuck originally, and one showing how there is plenty of room in the garage for the doors to open.
2) I picked up the car on Wednesday, and the screen froze once on Thursday and once on Friday. This isn't as big of an issue as the door problem, but it is still annoying. For others with this issue, has it been fixed?
I'm also going to ask them to look at the front driver's door - when it opens automatically, it sometimes opens into the car next to me in a parking lot.
