At it's worst, a heat pump will be the same efficiency as a resistive heater. At more optimal conditions (>14F) it is much more efficient.
LOL! Power Trunk, meh. If it were a Power Frunk, I'd be perturbed. Plan Hansshow is still in force if I keep my car! And yes the 3.1 (vs. 3.2) does rankle me a little. I want the *fastest* Model 3! However, with a Stealth's 18" wheels and lower rotating mass I think it still has the advantage off the line.
Ditto; I want the fastest Model 3. I couldn’t care less about the convenience of a power trunk or efficiency increase of a heat pump. If anything, I see those as more weight/more to break. Give me sub 3sec 0-60! Then again, I also understand I’m probably the minority profile [gearhead focused rather than tech/luxury focused].
I ... disagree with that. A PTC a heater is incredibly efficient - nearly 100% so. A heat pump below its balance point isn’t going to sufficiently warm without supplemental heat. Again, I’m going to reserve my judgement until we see a first winter with the heat pump ... but I’m skeptical it’ll do as good a job warming the cabin as the PTC heater. I care less about efficiency at those temperatures than I do being comfortable.
What you're thinking about as efficiency is power, a ptc heater may output more heat, but it is only 100% efficient converting electricity to heat, while a heat pump can be up to 300% efficient. Out of the efficiency range, a heat pump drops to 100% as well. The heat pump moves heat from the battery to the cabin, instead of using battery power to generate heat.
All meh 4680 Model 3 is when I'll upgrade. It will be very much worth it They should specify the weight of the driver in which they conducted and concluded official 0-60 times Curious if it's a fat dude or a lightweight
In a -5 degree environment, there won't be much heat in the batteries at all. I'm not saying at all that it's untenable - but I suspect the PTC heater will warm the cabin much more quickly in a cold-start environment. Curious how this plays out, is all. I love the heat pump, and the Octovalve is a genuine work of art... I just want to see how it performs at the outer edges of its envelope. Call me a skeptic -- and one who's been known to eat crow when I'm wrong.
From a dead cold battery yeah, but if you're going to superchargers or coming from your home charger, you'll have some heat it can scavenge. Bjorn has a few good videos on this and how it compares to his older model 3.
Cold soaked battery is much, much, much more likely for me than a Supercharger session. I’m going to let the rest of you try it out ... doesn’t make a bill of beans of difference to me as I’m not replacing my 3 or X anytime soon. Got another 8-10 years before I’m going to even consider it.
I have the 2021 refresh and the best thing about it is that it will not remind my of the god awful 2020 each time I fill out some paperwork!
don't care for chrome delete/ power trunk / center console double pane window (but only on drivers side???) is nice 350+ miles EPA is *very* nice compared to the 310 miles my LR AWD was getting when new. 350+ rating let's you do Amarillo - Trinidad nonstop leg year round as long as you stay 70 mph or under depending on the winds.
The range boost is the most interesting thing to me, however it certainly wouldn’t make me want to go through buying a new car and and lose a good chunk of value again. I’ve been back in the black for awhile now on my 2018 and am happy to be there.
I thought the PTC heater is still there as yet another fall back. Is this not the case? And yes the heat pump would be nice and would help with the family trips to the parts of Ohio with no public charging.
Has anyone used a dragy on a 2021 performance yet? I’m already getting 3.1 0-60 times on my 2020 with 1 foot rollout.
Use less electricity for the same amount of heat, down to somewhere in the neighborhood of 30F ambient It doesn't matter that a heat pump is no more efficient than resistance heating at 5F, unless you live in 5F all.winter.long, 24 hours a day, 7 days a week. E.g., most of my winter is in the 40s F when I am out and about in the car so a heat pump could make a big difference to my winter range. In point of fact it is less than might be assumed because I live in a climate that has a sunny winter so my use of cabin heating is minimal. So energy savings will be a YMMV but pretty clearly a heat pump is of some benefit outside of coastal California, Florida, and the Gulf coast.
Exactly. The interior...OKAY, but I actually like the cover for the charging pad...usb-c, had it in the late 2020 anyway, and with a taptes unit it doesn’t matter. I hate the power lift gates... especially since you can’t manually override without messing up the mechanism. Only things I would value are the range, heat pump! and maybe heated steering wheel, but outside of range, they are are not major to me. I like the chrome actually, but it’s a nice accent for an MSM car. I like black oh the other colors.
Not power, but what the heat pump industry calls capacity. They mean heat per time. For a heat pump it is power*COP It has been true in the past that heat pumps had lower capacity than straight resistance solutions although I don't know if that is the case in the new Tesla models, and if so at what temperatures.
