SocalGas & SGIP for 3 PW
af88
185
28
Cali
I'm receiving somewhat conflicting information on this, hoping people here with more recent experience and chime in.
I have 2PW already, would like to add a 3rd but wondering if I will qualify for the socalgas SGIP rebate on the third one.
My solar company said yes right away as there is now some 150% exclusion due to covid. Another solar company said if your solar system is not 3kW per PW than it is a automatic disqualification, not sure if that is true but my system is not 9kW or larger.
What is the requirement for 3 PW to receive the rebate?
Solar size requirement?
etc?
af88
185
28
Cali
I contacted another solar company who said in order to qualify for the 3rd PW SGIP they need to show proof of 15kW/hour usage otherwise that alone is a gate for approval
h2ofun
1,232
192
auburn, ca
Yep, each PW for SGIP has to show in their green button data at least 5 kw hour of home use during the last 12 months. So year, for 3, one has to show at least 15kwh of use during the last 12 months
BGbreeder
115
67
Bay Area
Just crank everything on for at least an hour and see where you get to. (Solar off)
AC, space heaters, blow dryers, dryers, ovens; all add up quickly.
We run under 3kW routinely, often less than 0.3kW normally, but using the heavy draw appliances, we hit 22kW easily, and we didn't have everything on.
The data convinced our utility that 3 Powerwalls were warranted.
All the best,
BG
af88
185
28
Cali
Boy, the information is all over, i was told 15kW/h daily.
That is an interesting approach. I'm almost beginning to think it is not worth the $2300 hassle for the rebate
h2ofun
1,232
192
auburn, ca
Nope, its hourly. I had to go back and do things since I was not approved on my first round, even thought I was using 240kwh per day.
af88
185
28
Cali
Right, 15kW/h (15kW per Hour), no way i can come up close to that, we average 0.5. I just don't think it is feasible to be considered for the rebate anymore
jjrandorin
Nov 28, 2018
7,197
7,980
Riverside Co. CA
I am not sure that you and @h2ofun are talking about the same thing (although the requirements might be the same). @h2ofun is likely talking about the SGIP equity and resiliency program, whereby powerwalls are paid for largely by the SGIP program (somewhere between 85% paid for to 100% paid for I believe).
@af88 appears to be talking about the "regular" SGIP (not the specific equity and resiliency "sub program"). These programs might have similar requirements for defining usage, and they might not. I dont know if they do, but I am fairly confident there are two different SGIP programs being talked about here.
af88
185
28
Cali
I just received correspondence back from SCG and they stated 15kW/hour and it is for the "regular" SGIP as I mentioned in my email yesterday not the resiliency program.
I don't know if there is different requirements for the other program but for the regular program it is 15kW/h and I'm waiting to hear back how many data points they need to meet this criteria as you clearly will not be using 15kW/h at all hours. So based on the number of data points they require some might qualify, most will not if you are a low consumption user.
h2ofun
1,232
192
auburn, ca
I need at least 1 hour of that in the last 12 months. I did 4 1.5 hours tests just to make sure I had enough data points when I submitted my green button data the second time.
af88
185
28
Cali
How did you manage 15kW in an hour. I can't get anywhere near that even if i run the AC and all my appliances
h2ofun
1,232
192
auburn, ca
10 heat pumps, 2 ovens, spa high speed, all lights, 8 TV, christmas tree lights, You name it, I had it running. I actually hit 35.2 at my highest.
Reactions: af88
BGbreeder
115
67
Bay Area
You just have to do it for at least one hour, to generate green button data covering an hour showing that under some circumstances you do consume more than 15kW/h.
As I wrote before, try the AC, dryer, etc. and see what you get to. AC and electric heaters add up quickly.
All the best,
BG
holeydonut
873
518
East Bay NorCal
Lol what... the SGIP application for 3 or more Powerwalls requires "greenbutton" proof that 15kW was consumed in a single hour during the last year? Seems... weird...
holeydonut
873
518
East Bay NorCal
Can you link me to where this language is? to define the 15 kW "peak annual demand" for 3x Powerwalls?
My large-scale SGIP was submitted this way, and PG&E didn't seem to say anything. I can't find language that says the minimum actually experienced is 15,000 kW in an hour.
My greenbutton data peaked at 11.5 kW used in an hour through chance; I didn't realize I had to try and hit 15 kW.
af88
185
28
Cali
You would have to contact PG&E to get that, I contacted SocalGas and got an email response. Also it is 15kW/h not 15000kW.
If you submitted it there is a chance they will reject it if it was recent.
