Soft OEM rims?
Discussion in 'Model S: Driving Dynamics' started by cinergi, Aug 19, 2014.
  1. cinergi
    cinergi Active Member
    MA
    There's been a few mentions I've noticed here on TMC about bent rims and I didn't think much of it (except "what the heck are you driving over?!?") ... until recently.
    I complained about a vibration or shimmy that would happen on the highway -- kinda like a wheel out of balance, but intermittent. Sometimes it was a smooth drive, other times not so much. I have the 21" rims from Tesla. I was told that all my rims are in various states of being bent ... :scared: I really haven't hit anything major -- nothing I haven't hit in any of my other cars (which didn't cause problems). And I know Aaron (who has 19's) just found out the same thing about his car. So now with the other TMC reports (someone here has been through something like 7 rims) and my car (and Aaron's) I'm really starting to wonder ... I want a smooth ride but why on earth would I replace all my rims (either 21's or 19's -- doesn't appear to matter) if they'll just bend again? Should I go with another set? How do I know those will hold up? ... thoughts?
  2. yobigd20
    yobigd20 Well-Known Member
    Skaneateles, NY
    if you feel the vibration increase as speed increased it's probably just tire imbalance.
  3. jerry33
    Texas
    It's remotely possible that there is a problem with the caster. Too much caster can cause a vibration like the one you describe. I'm not saying this is the case--just another possibility.
  4. Uncle Paul
    Uncle Paul Well-Known Member
    Canyon Lake,CA
    21" rims on Tesla will be much more susceptible to bending that the 19" because the lower profile tires provide much less impact resistance that the much same diameter tires on the smaller 19" wheels.
    This applies to all vehicles, not just Tesla.
    Switching to 19" will give your wheels much more protection, as well as a smoother ride.
  5. linkster
    linkster Active Member
    USAX2
    I am currently in Weston, "Taxachusetts" and I would NEVER drive on 21's up here. There is a significant difference between 19's and 21's WRT wheel damage and tire failure (yobigd20, tell 'em bluntly, like you normally do!)
  6. cinergi
    MA
    Except that it's inconsistent. I've had tire imbalance before. This isn't it. Plus Tesla investigated and rotated the wheels and they're visibly warped (they're clearly not perfectly round while watching them rotate).
    - - - Updated - - -
    I would just go to 19's except that I know the 19's are bending, too. So I could spend a lot of money only to not end up solving the problem.
    The potholes here aren't THAT bad (and I'm good at avoiding them). Like I said I've hit much worse (including in the Roadster!) and never had issues in other cars. Been living and driving here for 23 years. All four of my wheels are bent.
    The real question I'm asking here is do we know of better rims that I should get or should I just go with Tesla's 19's and cross my fingers? I don't want to spend another few thousand dollars and just hope ...
  7. green1
    green1 Active Member
    Calgary, Alberta, Canada
    I'm curious, I haven't been seeing threads about bent 19s, only about bent 21s, do you have more information on this?
  8. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    I've been reading TMC obsessively for a year now (really, just ask my spouse) and don't recall any posts about bent 19" stock wheels. Maybe it's happened and I missed it, but it's rare.
  9. SFOTurtle
    SFOTurtle Active Member
    Los Altos, CA
    +1. Nearly 23K on my OEM 19s and no issues.
  10. meloccom
    meloccom Moderator Aus/NZ
    Sydney Australia
    If your wheels are not too distorted there are companies that can straighten the wheel without replacement.
    I had a Mercedes that I couldn't get the wheels to properly balance until my tyre\tire shop sent the rims to be straightened.
    Ran the repaired wheels for 5 or 6 years after that without problems.
  11. cinergi
    MA
    I haven't done the research here to count who has what -- I'm only aware that a friend of mine who owns one with 19's has been told by Tesla all his rims are bent.
    - - - Updated - - -
    Interesting -- thanks for the tip!
  12. jerry33
    Texas
    There's no wheel made that can't be bent, but the odds of having a 19" bend on you are much smaller than the 21".
