I have had at least 5 to 7 of these cables break (I've lost count), in having it 26 months and 25,000 miles. I keep meaning to ask about it here, but figured others haven't had as much problem as me since I hadn't seen it here before. The Tesla Rangers said they haven't heard of others having a significant problem like me. I've shown them how I take the top off, store it in the trunk and put the top on and they saw no problem with how I did it. I do take the top off very often and sometimes it is hard to see if things are lined up perfectly (it's dark in my underground parking at home and often dark out when I go home at night and it's also hard to see what the cable is doing since the top is in the way).
Tesla has continued to give me a new cable each time one breaks.
Some of the cables have heat-shrink tubing over where they crimp (it looks like they are crimped) into the connectors on the ends, but it might help if that portion was longer and stiffer to keep the cable from bending at the connector. But I guess then there might be issues with the connector and tubing getting pinched in the slot that the cable goes into.
Useful info:
- As slcasner said having the rear cable broken isn't a significant issue. I've had that one broken/removed in significant rain with no leakage and there are no issues while driving. But having the front one broken is a problem when driving at highway speeds: the wind and/or interior pressure pushes the front edge up and it flaps very much.
- When I've broken the front one I remove both and put the good one from the rear on the front, until I can get a replacement from Tesla.
