Soft Top to Half Top conversion
Discussion in 'Roadster' started by Slackjaw, Aug 22, 2011.
Tags:
  1. Slackjaw
    Slackjaw Member
    Central NJ
    So, I'm driving along about 45 with the soft top on and the windows up (very rare for me) and notice a little draft on my neck. "Hmmm..." I reach above me to see if I can work out where it's coming from. A little poke to the soft top and the passenger side comes unclipped, folds back on itself and the heavy part hits the roll bar with an almighty THWACK before it all starts flapping around. Hey presto! A Half Top! Luckily the driver's side stayed attached and I didn't lose the whole thing underneath a semi truck. Also, the two cross pieces may have stopped it hitting me on the head.
    I had checked the top before driving but obviously (duh) not thoroughly enough. We do alternate between soft-on and off a lot in these thunderstormy days.
    Tesla Roadster For Dummies will need a box out: "if your soft top seems to be drafty, do NOT poke it with your finger as this may void your warranty". Good advice.
  2. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Wow, that could have been a lot worse. I hope it didn't damage the CF on the roll bar.
    Even better advice... when you install it, push down firmly on both sides of the bar, then pull up again on each side to make absolutely sure both ends are really latched.
  3. Roger Reid
    Roger Reid Old but effective
    Caldwell Idaho
    Here about a month ago I took my car to work and neglected to bring my soft top with me. Sure enough a lightning storm hit about halfway home. I started thinking about the irony of getting hit with lightning in an electric car. Inspiration hit me. I'm going to my local sign shop and have some lettering made for my (carbon fiber) license plate border that says "Ride the Lightning".:tongue:
  4. Doug_G
    Ottawa, Canada
    Hate to tell you this, but the soft top isn't going to protect you against lightning. :wink:
    Your safest bet is to drive beside a Hummer, also known as "your portable lightning rod".
  5. Slackjaw
    Slackjaw Member
    Central NJ
    I'll be doing that now. I had a good look at the car as soon as I put it in the garage; no visible damage at all. Basically the fabric covering on the passenger side soft top "beam" was what impacted the CF on the roll bar. I was lucky it didn't hit my finger.
    One quick question: Do you need to push the two clippy things toward one another when you install your soft top? We have to do that or they don't clip into place. I suspect that's how we had installed the soft top last night, but they hadn't snapped back completely.
    I think when we got the car, Tesla Dude demonstrated installing the soft top without pushing the clippy things toward one another, i.e. just by latching the black pins and twisting the bars down on each side, but we've not been able to do that consistently.
  6. Doug_G
    Ottawa, Canada
    You shouldn't have to pull the clippy things, although I used to when the top was new. But it's a good idea to put your thumbs on them and check that they're engaged properly.
  7. strider
    strider Active Member
    NE Oklahoma
    I need to do that on the first side I clip in. I find that if I don't I end up just levering the fixed pins up. So I'll retract the pins slightly on that side and then give it a tug to make sure it's latched. On the second side it goes right in (more leverage to keep the fixed pins in as they are pulling against the other side) but I also give it a tug as well. Glad nothing was damaged!
  8. vfx
    vfx Well-Known Member
    CA CA
    This sounds like the procedure on the Mesh Top. The pins are sprung out-only so you have to push them towards each other to cock them back. Then releasing them while in the correct top down position seats them. The Tesla/Lotus top is a bit simpler for the operator. With either top though as, Doug says, best to pull up on each side before you walk away.
  9. bonnie
    bonnie Oil is for sissies.
    Columbia River Gorge
    Whews, Slackjaw (and Ms. Slackjaw) ... glad that [what did you name your car?] wasn't damaged. And very glad you weren't damaged. :)
  10. Slackjaw
    Slackjaw Member
    Central NJ
    Thanks... it was certainly a bit of unexpected excitement!
    Cautiously, very cautiously, we named the car Naomi. If you got NOCO24U then that's an easy one.
  11. NigelM
    NigelM Recovering Member
    Northern Virginia
    Sodium Monoxide Mibellium? :confused:
  12. Slackjaw
    Slackjaw Member
    Central NJ
    #12 Slackjaw, Aug 24, 2011
    Nice try :biggrin: ... but "Mibellium"? No soup for you!
    The correct answer is the National Applications Office in Michigan, known as NAO, MI.
    Not.
  13. vfx
    CA CA
    So to be clear, who named the car?
  14. TEG
    TEG TMC Moderator
    #14 TEG, Aug 24, 2011
    Is there some other meaning besides the fact that your hyperlink reminds us that there is a famous actress known as Naomi Watts ?
  15. bonnie
    Baby Turtle welcomes Naomi.
  16. Slackjaw
    Slackjaw Member
    Central NJ
    Um.... no. But I did say it was easy.
