Software 2020.36.x
Niek
204
203
Utrecht, NL
Software 2020.36.x komt er aan, hierbij de release notes:
Autosteer Stop Sign and Stop Light Warning
Your car may warn you in some cases if it detects that you are about to run a stop sign or stop light while Autosteer is in use. This is not a substitute for an attentive driver and will not stop the car.
Green Traffic Light Chime - Available only in USA
A chime will play when the traffic light you are waiting for turns green. If you are waiting behind another car, the chime will play once the car advances unless Traffic-Aware Cruise Control or Autosteer is active. When Traffic Light and Stop Sign Control is activated, a chime will play when you can confirm to proceed through a green traffic light. To enable, tap Controls > Autopilot > Green Traffic Light Chime.
Note: This chime is only designed as a notification. It is the drvier\'s responsibility to observe their environment and make decisions accordingly.
Cruise Set Speed Improvements - Available only in USA
Quickly adjust the Traffic-Aware Cruise Control or Autosteer set speed to the current speed by simply tapping the cluster speedometer. You can still tap the speed limit sign to adjust the set speed to the speed limit.
Speed Assist Improvements - Hw3 - Available only in USA
Speed Assist now leverages your car's cameras to detect speed limit signs to improve the accuracy of speed limit data on local roads. Detected speed limit signs will be displayed in the driving visualization and used to set the associated Speed Limit Warning.
As usual to adjust Speed Assist settings, tap Controls > Autopilot > Speed Limit.
Bron: 2020.36 Official Tesla Release Notes - Tesla Software Updates
BMW740iL
1,072
447
Amsterdam
Jeez, wat een misser dit. Een extra klik omlaag met de rechter stalk ligt toch veel meer voor de hand dan dat je met je hand moet zoeken naar een tap op het scherm.
Inferi0r
28
23
Netherlands
Lijkt de eerste update te zijn echt voor HW3 rijders.
Dus kom maar door met die beloofde upgrade voor de Model 3 Elon!
Anyway, vorig jaar hadden we 10 grotere updates en kwamen we uit op 2019.40 in December (elke update met releasenotes +4)
Nu in augustus al 2020.36, dus we zijn in September al over de 2020.40 heen.
Niek
204
203
Utrecht, NL
Nog wat meer interessante info:
This is an early version of the rewrite. I don’t like to speculate but I will say since this update is public release and didn’t go to early access program. Everything new is running in shadow mode. Nothing major yet. Major stuff in 1-2 months. Leaning towards 1, saying 2 to be safe. Here is the speed limit sign visualization for those interested
Imgur
Bron: 2020.36 Release Notes includes Green Traffic Light Chime and Speed Limit Sign Recognition!! : teslamotors
TheoSchijf
414
409
Utrecht, The Netherlands
Het weeknummer heeft weinig met de grootte van een update te maken. Tesla werkt met sprints van 4 weken, dus max 13 sprints per jaar. Sommige sprints worden overgeslagen. Sommige sprints bevatten weinig voor eindgebruikers, andere juist veel. Aantal sprints zegt dus weinig.
Per jaar echter, als je terugkijkt, zijn er heel wat extra functies toegevoegd. Uniek in autoland.
DuurzameHenk
356
689
Salland NL
In deze versie nog geen test van de nieuwe Autopilot versie:
Reactions: Hbrink
jpvdheijn
525
404
Baarle-Nassau, NL
Misschien even een side note. Ik merk dat de AP1 verkeersbord herkenning moeite heeft met de recente uitgerold verkeersborden van de overheid op de snelwegen met een dubbele snelheid van 100 en een andere snelheid boven elkaar.
Te begrijpen naar mijn mening.
Phil V
2,127
1,683
Ten zuiden van Aalst (B)
Sedert een paar updates wordt de snelheidsbordenherkenning van AP1 overruled (vaak ten onrechte) door de kaartsnelheden. Vaak zie ik op de Antwerps ring overhead borden op 70 staan, het verkeersbordje in het dashboard toont die 70, maar AP gaat naar 100.
Hbrink
Lazy, but dangerous when active :)
Nov 8, 2017
1,682
793
Naarden, NL
Inmiddels (conform TeslaFi) 36.3 in de uitrol. USA only nu nog en HW3 / vnl Model Y. Weinig hoop voor NL dus...
Reactions: Cely
