Software/ firmware questions....
Discussion in 'Roadster: Technical' started by chris22104, Mar 17, 2012.
  1. chris22104
    chris22104 Member
    Hi!
    First off, what's the difference between software and firmware? How do I figure out what software (or firmware) my (recently purchased) used 08 roadster currently has in it? (Built 1/09.) What is the latest update for the PEM 185? And if mine is not the latest, is it possible to update it myself via a download online to a jump drive or the like for transfer purposes, or is it something only a dealer can do? Thanks again guys!
  2. jerry33
    Texas
    Firmware is burnt into a chip such as an EEPROM. Software is stored on storage devices, such as a hard drive or SSD drive, and loaded into memory before running.
  3. chris22104
    chris22104 Member
    #3 chris22104, Mar 17, 2012
    Thanks Jerry! I guess I'm asking about software updates then.....(if there were any...)
  4. jerry33
    Texas
    Sorry, don't know the answer to that.
  5. markwj
    markwj Moderator, Asia Pacific
    Hong Kong
    When you switch on the car, the firmware version should flash briefly in the top right of the VDS. It is also recorded in the logs files.
    I suspect that the latest versions are 3.5.18 and 4.6.4, depending on your car, but you would need to check with Tesla to be sure.
  6. chris22104
    chris22104 Member
    I can't find it on the vds at all; key in or out, started or not. I guess I'll have to get a jump drive stick to download the log files and search for it in there somewhere.....
  7. markwj
    Hong Kong
    Chris,
    Try with car off and vds off. Wait five minutes for car to sleep. Then insert and turn on key. As vds switches on the firmware version will flash in top right. Works on 2.x cars, but not sure about 1.5s.
  8. markwj
    Hong Kong
    The definition has become blurred over time. It used to be that firmware was fixed with the hardware and software was changeable, but then they went and introduced flash firmware.
    The definition I like is that firmware is software for embedded devices.
  9. slcasner
    slcasner Active Member
    Sunnyvale, CA
    Yes for 1.5 cars also.
  10. NigelM
    NigelM Recovering Member
    Northern Virginia
    There may be different Firmware releases for different model years. At my annual service recently Tesla updated mine to: "FIRMWARE 4.6.4 RELEASE (MODEL YEAR 10, 11)".
  11. chris22104
    chris22104 Member
    I've been keeping the car plugged in. The vds has not turned off. What's the secret to get it to turn off?
  12. NigelM
    Northern Virginia
    #12 NigelM, Mar 18, 2012
    It doesn't turn off when the car is plugged in.
    There's a "sticky" on the owners manual here with a link to download the manual as a pdf.
    If you need a Mobile Connector Users Manual, you should be able to get one from Tesla. I don't know if there's a download.
  13. chris22104
    chris22104 Member
    I do have the manual; I just didn't remember. Thanks Nigel! But I still can't get it to pull up the software version on start-up, whether just touching the screen or putting the key in and forward.....
  14. NigelM
    Northern Virginia
    Watch the top right corner of the VDS the whole time:
    1. Apply the brake
    2. Insert your key
    3. Turn key fully to start the car
    4. For a second or two, you'll see the Tesla "shield" and in that top right corner you've been watching there will have been a number
    That's your firmware version. Here's a pic:
    Here's a page that shows the different screens. Although it's an old firmware version it might be helpful in future.
  15. NigelM
    Northern Virginia
    Latest firmware version just out is 4.6.5 and follows up on HID light installation.
    (Cross posted here.)
  16. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    What exactly does it do to support the HID lights? I have the new headlights but the firmware wasn't out at the time. They still work but think the new ones keeps them from flickering when you turn the car on or something. Thanks.
  17. NigelM
    Northern Virginia
    Good question. I didn't really follow up on that as they worked fine with version 4.6.4, which I already had. I'll probably see the Ranger again tomorrow so I'll ask him.
  18. NigelM
    Northern Virginia
    OK, it's a 2 part upgrade 4.6.4 and 4.6.5 and basically just tells the car that there are new headlights. Ranger told me that usually when it's in two parts like that the latter part fixes bugs in the first part, however he knew of no bugs in 4.6.4.
  19. chris22104
    chris22104 Member
    On my 08 roadster, my software is 3.6.7, with a small "11" underneath. So besides the headlight stuff, what other differences have there been? Should I upload something newer for my 08? And if so, how? Are your 4.6.4 and 4.6.5 you mention for the 2010 and/or 2011's, or possibly for the sport version? I wouldn't want to program in something not compatible with my older 08 non-sport.
  20. dsm363
    Nevada
    They are for the 2.0 and 2.5s. Tesla updates your firmware during any Ranger visit or during an annual visit so no need to worry about wrong version being added.
