Software Update 2018.32.2 3817fdd
fredz
87
51
Tesla
I got it, and first thing I noticed is that the car doesn't go to sleep anymore. Major problem for me. X 100D AP 2.0. I'm monitoring the situation to see if it's temporary.
Reactions: djole and hh83917
SpudLime
1,420
2,452
Leesburg, Va
I hope you mean it doesnt go to sleep quickly anymore. If its parked for a while, I hope it still sleeps to save battery.
SpudLime
1,420
2,452
Leesburg, Va
No - it doesn’t go to sleep at all anymore. Did a few reboots both hard and soft, changed my password, checked the settings... I hope it’ll still go to sleep soon, but doesn’t look good.
Not sure how you would glean doesnt look good so far. It would have to be left alone for an hour or so before going to sleep. right? That would make sense to me.
Tyshawn
35
22
Hampton, GA
I got the update today from the SC. After the update I took a look at the release notes and it was BLANK.... Any thoughts...
Reactions: wanche
MP3Mike
14,978
31,851
Oregon
Strange this update when we should be getting V9.0 within a week (August has one more week left)
Did you just publicly announce that you are a member of the EAP, early access program?
Because they are who is supposed to get v9.0 this month.
g1000x
171
152
Denver
My car just got this tonight. The install took about 40 minutes, the longest install since I got the car. Hopefully some good improvements.
morbot
212
Seattle
Got the update to this version last night.
I did notice that my traffic is refreshing more frequently now. Still a bit of a delay after starting up the car, but I don't have to manually refresh it or use the navigation just to get traffic updates.
I've encountered a really crummy bug though:
When listening to Slacker Streaming, if I use the steering wheel "forward" (or backward) button - it doesn't work switch streaming stations.
I can switch streaming radio channels on the media player screen, but I cannot use the steering wheel.
Even worse, if i try to switch stream channels on the wheel buttons - it seems to make my media player freeze after 2 or 3 attempts.
I've repro'd this 3-4 times on the way home from work today & each time I have to reboot the infotainment system.
Once it's frozen, it'll finish the existing song but it will not respond, even to screen inputs. You cannot change stream, cannot skip song, cannot switch to radio, either via steering wheel shortcuts or via the media player on screen. :(
If anyone else could see if this is happening to them, would appreciate it
Reactions: AnxietyRanger
Daniellane
2,372
2,655
Camas, Washington
I just finished installing the update and immediately tested the steering wheel functionality with regard to the infotainment system. Everything seems to be functioning perfectly forward and back.
Only thing I noticed which I have noticed on the last few updates is that Emmersive Sound Setting reverted to standard. It was set to high before the update.
Also, Mirrors seemed to function normally.
Vallancey
New Member
Aug 23, 2018
Los Gatos, Ca
I just installed my latest update today. It said minor bug fixes. However, when I got home and charged, the preset times and amperage setting on my car were wiped out. It started charging at 48 amps on a 30 amp cable. Nearly burned down my house!
boonedocks
2,547
3,505
Gainesville, GA
You need to call your electrician back out. Something “nearly burning your house down” is an installation issue. That should have flipped one at least 2 breakers IF INSTALLED correctly!!!
ghostrunner
104
188
Edmonton
What size of breaker is on the cct?, if you have a cord rated for 30 amps the breaker should be 30 amps and should have tripped.
