This happens to me too but I figured out why - it changes when you change driver profile from easy entry to my driver profile. Silly to associate the seat heaters with the driver profile, I know...I am pretty much only annoyed that my wife's seat heat gets turned off constantly instead of staying on. Driver's side is always fine.
Hmm I'm still on 8.5, maybe they replaced one bug with another... that would be stereotypical Tesla.Not for me. I don't use easy entry. It happens when I shift gears to reverse out of my garage. Wife will turn it on when she enters (it used to persist as on). Then after I back out, it turns off again when I shift to drive. Very annoying.
Even regular autopilot has been pretty embarrassing lately. We did a 2 hour drive yesterday and there was so much phantom braking my wife almost begged me to turn off autopilot. This hasn't happened in the 2 years I've owned the car, so my prediction that phantom braking would get a lot worse before it gets better was something I really wish I wasn't right about...I didn't have this issue on 8.5 but I also only had 8.5 for a day before getting 2019.12. Hopefully Oz gets NoA and unconfirmed lane changes because NoA is mostly useless and it becomes slightly better without having to confirm changes (only in rural areas with mainly trucks/lorries on the road, when there is traffic ULC is useless).
Do you mean it will mess up NoA lane change even if both profiles have it set the same way? That’s a bug, I’d think.Not for me. I don't use easy entry. It happens when I shift gears to reverse out of my garage. Wife will turn it on when she enters (it used to persist as on). Then after I back out, it turns off again when I shift to drive. Very annoying.
EDIT: One thing I did learn was don't accidentally switch driver profiles while on a giant road trip because it will screw up NoA unconfirmed lane change option (switches it to OFF and you cannot change it to ON without being in park). Unconfirmed lane changes are so much better than flicking the AP stalk (and it did lane changes WAY BETTER. I had tons of aborted changes when it was off and not one while it was on).
If so, it’s probably because there’s the confirmation screen when you turn it on and it doesn’t check for both NoA states being identical.
6/18 definitely MCU1. I'm hoping they allow an upgrade to MCU2. They pretty much no longer support MCU1 and all new features look to be branching off for MCU2
Why should they do upgrades? Just fix the darn software to be able to run more efficiently. Honestly, the car does not do anything more than it ever has, so for MCU1 to be chocked up as obsolete is crazy. This entire point is supported by the release last summer that came out just prior to 9.0 where they cleaned up the software, added some acceleration, and the MCU1 was running faster than ever before.
That was a very short lived optimization. The browser now is non-functional and the constant nav of v9 is taxing the system such that it has issues playing streaming music. Its like it went from being able to chew gum and walk to stumbling around and swallowing the gum.
I’ve personally found the 2019 updates to be fine on both our AP2.5 3 and AP2.0 S.
The P90L that I have on order is on 2018.48.12.1. I’m guessing I need to call Monday and tell them not to update it prior to delivery?
You must be lucky. I've had my cameras all checked and tightened and so on and it made no difference. I keep getting little brakes when passing cars in other lanes, sometimes I get mysterious braking with nothing around me almost to a complete stop, and sometimes I get it matching the speed of the car in the adjacent lane instead of the car ahead.Me too. No phantom braking for me at all with AP2. I think I got lucky with my car and everything is really well calibrated and positioned.
