Software Update Not Downloading
Tfunk
9
4
Vancouver
I just had this recently (2 days ago). I found a thread on another forum that helped out, here's what I did:
1) Power Off using touch screen and let it sit for 5 minutes.
2) After 5 minutes power back on using the brake, and then power cycle using brake and both thumb wheels.
3) Power cycle again using brake and both thumb wheels.
After I did this the car had reset the download and everything went smoothly. Hope this helps
Reactions: bcpm3p and NielsT
andrewxc
24
4
Columbia, MD
FIXED:
I just went through this. I entered the password for my home WiFi, to which it would not automatically connect, rather suddenly. It then showed the "waiting" symbol indefinitely, until it timed out. When I hit the WiFi again, it made me enter the password again, and cycled through this process.
When I took it in for service, it turned out that this was a known issue, and would not get fixed, because the WiFi firmware was broken (infinite loop: (0): need to update firmware to connect to WiFi; cannot connect to WiFi because the firmware needs to be updated; GOTO(0) ). The service station pushed the update directly, updated the firmware, which got the update to me, and I updated it as soon as I got home that evening.
This ALSO (finally) downloaded the Caraoke / Streaming Audio / new updates that everyone has been talking about.
Reactions: lUtriaNt
alarti
New Member
Dec 16, 2019
Weston, FL
Thank you! This did it for me. I was a bit doubtful about the second power cycle but sure enough, after the second one it started downloading like a charm!
Reactions: webby87
Young
44
16
Palo Alto, CA
This worked for me. The car turned on by itself in less than 5 mins after step #1. I rebooted twice after that.
TonyS11
New Member
Oct 26, 2019
2
0
Los Angeles, CA
I just wanted to further reaffirm this - it also worked for me too: 2020.4.1 Download was stuck at a millimeter on progress bar and it said "connect to WiFi to download" even though car was connected. Followed the steps, the download reset and is currently progressing as I write this, Thank you
MileHiPM3
13
10
Denver
Just another data point here. I had this same issue since I took delivery of my car 8 weeks ago. The power cycling procedure above did not work for me (Not trying to sound unappreciative!) BUT a factory reset from the controls DID!
I think it’s under Controls > Settings > Service & Reset > Factory Reset >
I lost my stereo/seat memory settings etc. but once the reset was complete, my car started to download the update within 20 minutes.
Mchesnoff
49
13
Los Angeles
How do you power off from the touch screen? Currently having this issue with the new update.
AdamVIP
516
290
Open a ticket with Tesla on the app and put software update as the reason. Explain your download is frozen and when they get back to you they can resend the update over 4G. I had that done 2 updates ago and it worked. I could never get reseting the screen or car to work.
Jun 12, 2019
28
27
Montreal
I tried this and it had no effect. The download is still stalled at 0% by "connect to wifi" even though wifi is connected and working fine. I'm on 2020.20.12 (trying to download 2020.20.13).
Johannotation
New Member
Aug 9, 2020
Norway
This procedure did the trick for me. I signed up here just to be able to write thanks for the tip. I unplugged both USB Ports before going through the steps. Unsure whether this is significant or not.
