So I've only recently moved up from 5.6 to 5.9 and immediately noticed that the range was altered. Previously the best I get on an 90% charge was 222 (I've never balanced the pack). Once 5.9 was updated to my +, the 90% turned to 230. Without balancing my pack, I'm now wondering if the software made certain assumptions that actually would affect my true range since my battery is out of balance. Anyone with insight on this? TIA
There is another long-running thread on firmware 5.9 that discusses this, among other things. Perhaps the mods could merge this post into that thread?
Tesla simply changed how they calculate estimated range. They just tweaked how they read the raw data they collect from the battery sensors.
If the pack is not balanced, then wouldn't the sensors read incorrectly? Unless there is somehow a way for the sensors to tell if the pack is not balanced and adjusts for it.
The only way to know is to balance the pack and see if the numbers improve. An unbalanced pack means that some modules/cells have a different level of charge than others. This causes the total available energy in the pack to be lower than it should be because it's the border cases that determine how full the pack can charge (or drain going the other way). So if one module/cell is at the State of Charge (SOC) limit and the rest are only at 90%, they won't get charged anymore. At the bottom end, if one is at low SOC limit, the others won't be used either.
My sub 100% charge rated range miles increased on 5.9 ( e.g. 75% went from 170's to 186) but my 100% stayed the same at 252 rated.
"Standard" (90%)? charge on my 60 went from ~176-178 to 186 after 5.9 I feel like it was 190 new although I'm not entirely sure.
