--> After:
Is it possible to view individual solar panel production with Solar City/Tesla Energy's apps? We've been shopping around for solar and are probably going with Tesla Energy. When I've seen the online interface for other companies, many show each solar panel and you can see which might not be producing as much as they should. I assume Tesla has this information...but are you only able to see the total for the entire system vs. individual panels?I am on 1.11.2 and noticed a minor fix to the Energy Usage summary for weekly usage. The 2nd set of numbers below the Powerwall (green) and the grid (light gray) were cut off slightly when I looked at a specific day (by holding on the specific day of the week). Now it is fixed and I can read the numbers correctly. See below sample.
Before: View attachment 275769 --> After: View attachment 275768
My Tesla solar panels have a Delta inverter. I don't think they have that information. I can see on the inverter itself that it shows each string, but I don't have that info on my app. You probably need a solaredge inverter or micro inverters, which you may not get with Tesla. For us I think if we had a shading problem they would consider using a solaredge inverter but there wasn't a benefit if you don't have a shading problem. Best to ask them, but keep in mind that it's up to the Tesla engineer designing your system on which inverter you get, you don't really have control over it (at least I didn't when I pushed a little for the solaredge one).Is it possible to view individual solar panel production with Solar City/Tesla Energy's apps? We've been shopping around for solar and are probably going with Tesla Energy. When I've seen the online interface for other companies, many show each solar panel and you can see which might not be producing as much as they should. I assume Tesla has this information...but are you only able to see the total for the entire system vs. individual panels?
Thanks for the info. I'll bring it up during the site survey.My Tesla solar panels have a Delta inverter. I don't think they have that information. I can see on the inverter itself that it shows each string, but I don't have that info on my app. You probably need a solaredge inverter or micro inverters, which you may not get with Tesla. For us I think if we had a shading problem they would consider using a solaredge inverter but there wasn't a benefit if you don't have a shading problem. Best to ask them, but keep in mind that it's up to the Tesla engineer designing your system on which inverter you get, you don't really have control over it (at least I didn't when I pushed a little for the solaredge one).
This could be similar to your problem:Since 25.01.2018 my Powerwall got firmware 1.11.2 - unfortunately with 2 new failures and not solving the 5% discharge limit:
When the PV powers up the Powerwall charges normal until 4,6kW. As soon this level is reached the charging power reduces down to 3,1kW, even up to 8kW are coming from the roof, until the Powerwall is fully charged. With 1.10.2 charge was always at 4,6kW.
Second: when the Powerwall discharges in absence of PV Power and reaches the 5% limit it stops supplying, but right away starts charging with 1,7kW from the grid until 6% when it stops charging and starts discharging until 5%. At this point I have to put the Powerwall on standby.
Tesla searches for the issue since 1 week, no results yet.
Anyone else having this issue?
I have the iOS app version 3.3.0 (68bf3eec4) and Firmware 1.11.2 and the "Customize" option is there if I swipe up on the area with the "Power Flow", "Self-Powered" and "Backup History" optionsCarefull everyone, the latest update (3.3.0) to the iOS app takes away the Customize facility. Looks like the same version of the Android app still has the functionality.
I think someone said they had to close the app and restart it to get it to come back. I use Android and I never lost it.I have the iOS app version 3.3.0 (68bf3eec4) and Firmware 1.11.2 and the "Customize" option is there if I swipe up on the area with the "Power Flow", "Self-Powered" and "Backup History" options
I just checked and I now have 1.12.0.I've just had 1.12.0 pushed to my PW here in Australia. So far I can't spot any difference at all. Certainly no TOU settings anywhere.
I decided to try to login to the Wizard to check for TOU setup, etc., but it says "Invalid Credentials"I just checked and I now have 1.12.0.
I called my installer today. They (or Tesla) added a 'S' in front of the serial number for the password. That may be the case for some other installs, so I thought I pass it along.Is the password always the serial number?
