Yes, I'd like one day to have a PV system on my house, TEG. Just not sure how well it works for a Mexican tile roof like I have at the present time.
My recently added source of power for my Tesla Roadster (and everything else). This is a 13.5 kW Sunpower installation.
Beautiful! I assume those are 225 W panels then? How many inverters, and what size?
My, much more modestly sized, 5.16 kW Sunpower system is going up on Wednesday.
Yes, it is 60 of the 225 W panels with 2 - 6000 W inverters at this time although we will probably be going to 7000 W inverters.
Donauker you also have a really nice house. Does your system cover all of your energy needs? Or does it cover more? Or less? I'm guessing with the size that you would at least cover your energy needs.
Another question, is that single solar panel (or at least what looks like a solar panel on the left smaller section) for hot water?
Since my heat is all electric (geothermal heat pump)...
Does the pump use that much power? I was under the impression that they were pretty efficient. Or is it because, as you said, your house is older that it does not retain the heat as well so you need to use it more than you would probably like?
Another question, if you don't mind. What is the square footage of the roof with all the solar panels? Really just wondering out of curiousity. And something else I just thought of, since you mentioned your array will only cover about 75% of your usage, how much electricty do you use a year (if you don't mind me asking)?
I love talking about this stuff but don't have many people to talk to around me about it, so sorry if I'm not asking to many questions :biggrin:.
-Shark2k
I have 24 of the 225W panels, but only a 4000W inverter.
-Shark2k
per annum?
Don, terrific installation!
I have a Sunpower installation also, but I think it was slightly mis-engineered.
I have 24 of the 225W panels, but only a 4000W inverter. I think normally the peak power output is only seen during a rather brief time when the sun is just right, but I get a full 4000W over most of the day. I think I'm losing a lot of my power potential. I get about 32KWH a day in the summer, but I think I might be able to do 40 or more.
Need to work on upgrading the inverter, but I don't think Sunpower sells directly to homeowners. I still have a lot of free roof area too, so maybe I need an even larger redo.
