Solar Charging
Discussion in 'Model S: Battery & Charging' started by greglaw, Mar 22, 2014.
  1. greglaw
    greglaw Member
    Birmingham, Alabama, United States
    Does anyone know if it's possible to trickle-charge the 12-volt battery using a small solar panel?
  2. Raffy.Roma
    Raffy.Roma Active Member
    Rome (Italy)
    I saw on Amazon a solar panel useful to charge the 12 volt battery.
  3. KJD
    KJD Supporting Member
    SLC, UT
    It should be possible to charge the 12 volt with solar. I used to do that with my Volkswagen EV
  4. greglaw
    greglaw Member
    Thanks. I trickle-charge the lead-acid batteries on several ICE machines, and I believe that the 12-volt gel battery in the Tesla can also be trickle-charged. This should preserve some of the charge in the main battery, since the main battery charges the 12-volt battery.
