Another reason to go with microinverters like Enphase is for system expansion. I installed a 2.8kW system in 2008.
This was a self install and I couldn't use Sunpower panels because they only sell through installers. I had a solar house (solarelectricsupply.com) spec the total system for me with Sanyo panels (just as efficient as Sunpower it turned out) and a central Fronius inverter. When I did the install (old Spanish, tile roof) I layed down extra racking for future expansion.
Two years later, I expanded the system to 4kW but the Sanyo panels were much more expensive than several other mono-crystalline panels on the market. Using Enphase allowed me to expand the system without requiring I stay with the same panel type (important for MPPT) and I saved a bunch of $. Since then I've expanded again (2 EVs), so I now have a 6kW system for a whole lot less than it would have cost if I didn't have the microinverter option. My last 2 kW cost me $1.40/W (self install helps a lot here) all permitted and to code.
I've had no trouble with the Enphase so far but of course I'll have to climb on the roof if there's a problem. I have had the big Fronius inverter fail. It was replaced under warranty but it was a much bigger job than swapping out an Enphase. My $0.02.
This is not the case always. We installed an enphase system with m190 inverters and for a warranty repair we had to run a whole new trunk line because they couldn't replace it with a m190 because they didn't have any.
Its easy to expand a central inverter system. I just expanded mine. It doesn't make sense to expand by 2 or 3 panels at a time. You still legally have to go through the permitting and interconnection process of which there are usually fees so it is not cost effective.
When micro inverter strings are designed they are designed for the max number of inverters per circuit, this leaves no room for another inverter(s) with out having to run another set of wires for another circuit.
On top of that if you want to go the route of expanding with out keeping the same panel types go with the new sma tl series inverters. They have a mini emergency power system built into them and you can do unbalanced strings using different panels.
Central inverters should never be sided with room to spare, if they are then the system wasn't designed right. Even a 2kw central inverter system will come in more cost effective than an enphase micro system. And the larger the system the less financial sense micros make because their price per watt is high. The inverters look cheap but that trunk cable is where they make their money.
If you don't believe me, go to Chicago next month to SPI and ask attendees if they are an installer integrator, if they say yes, ask them if they would recommend enphase, I guarantee that the majority will say no.
The only reason to go micros is for a partially shady site (and even that is less now because modern central inverters handle shade way better than they used to) that probably shouldn't have been sold in the first place. I have turned many people that wanted solar down because of that neighbors tree that you can't do anything about.
We had a DOA fronius once. To change it out we stood on the ground, removed 4 screws, pulled it off, dropped the new one in place, replaced the screws and turned it on and it was done. Way better than roping in, climbing on the roof, lifting a panel in the middle of an array on the roof, loosening the ones on each side of it, replacing the ground clips, removing the inverter from the rack, replacing it with a new one (if there hasn't been a model change that requires a whole new circuit to be run) torquing everything back down and climbing down from the roof and going through the discovery mode on the enlighten box to make sure it is fixed. I'll take the central inverter change out any day. And other than the DOA fronius, we have never had a central inverter go bad in 6 years (over 700Mw of <20kw residential systems). We have changed out 3 enphase on 3 different systems just this month. We have a handful of enphase customers that have never had an inverter go bad, they are the exception. I hope you are the exception.
