Solar Power Stickers / Static Clings
You can print your own. The cling material is available in 8½x11 sheets — the one I've used is called "Clear Window Decal Sheets". Print the text/graphics in mirror image on the sheet and then spray over it with a lighter paint color that will show up the text: white if you used color for your printing background or some other color if you just used black text/graphic, to make it easier to read — I've used gold paint for that. Covering the paint with a clear coat can make it more durable. Then peel off the backing on the static stick side and place on the inside of the car window.
Something like this ought to work:
Inkjet Clear Ultra Cling, 5 Sheets
A bit of work but rather a fun art project.
