  • The final cut of the 8th episode of the Tesla Motors Club Podcast, featuring Balazs Biro, of the prominent Hungarian EV channel Villanyautósok, is now available. You can watch it now on YouTube or listen to it on all major podcast networks.
Solar System Type
What kind of Solar install do you have in your home?
  • Total voters
    24
Hello, Just curious as to what type of install the forum members have in their homes. I have a full home backup, 48 (400w) panel ground mount array, 3 Sunnyboy inverters, 3 Tesla Powerwalls. I don't see any power blips or anything when the power goes from solar, to powerwall, to grid or any combination theirin, etc. I am happy with how it works. Thanks to all who respond.
jjrandorin
Moderator
Nov 28, 2018
14,194
17,921
Riverside Co. CA
You likely will, at some point, its pretty impossible to avoid noticing it in the specific circumstances you tend to see them, which was covered in this thread:
I would be categorized as having "partial home backup" because my tesla wall connector is not backed up, but it is the only circuit that isnt.
Reactions: 201reyes
gpez
794
658
Partial Home Backup. 8.6kw system and only 1 Powerwall so fairly limited in what can be backed up. Have natural gas stove, tankless water heater, and furnace. High wattage circuits are not backed up: A/C, oven, dryer, level 2 EV charger.
We have full net metering so the Powerwall is backup only.
Reactions: 201reyes
I selected partial only because my AC and pool are not backed up on my one PW; everything else is. We have natural gas for everything: oven/range, dryer, water heater, furnace so they can easily run along with everything else on one PW. The only two things I have on 220v are the AC and pool pump. I would need another PW to run those in the event of power loss. The powerwall can run everything, including my pool and AC during my peak time as long as I am connect to the grid.
Reactions: 201reyes
interesting, at night, if the draw is greater than the batteries can supply, the grid kicks in, but there is no 'hiccup' 'blip', seamless so far. I've intentionally ran (to test) the batteries down to their 'reserved for power outage' setting' - 25% and the switch to the grid is seamless. I am on the lookout for the 'blip' because it seems too good to be true to be that smooth, still knocking on wood though....
gpez
794
658
How's the tankless water heater? what does it heat up?
How is it? Awesome - efficient (both with electricity and natural gas) and never runs out. Not sure what you mean by what it heats up...it heats water :)
I've told this story on the board before but the tl;dr is we have a power outage before we had the Powerwall installed and I was able to take a hot shower by using a larger computer UPS to run the water heater. Would not have been possible with an electric tankless heater.
jjrandorin
Moderator
Nov 28, 2018
14,194
17,921
Riverside Co. CA
There wouldnt be one in that case. Any "blips" would be in transition between a "grid up" and grid down / no grid" situation, but its covered in that thread pretty well so dont want to take this one too far off topic.
Reactions: 201reyes
