I began looking at a solar system with battery in November 2021 & finally settled on a system in jan 22 with install planned initially for April which then moved to mid May. Like many others on this & other PV forums I initially planned getting a system with a PW2.
Ridiculously long non guaranteed delivery times for the PW2 steered me toward alternative systems.
I eventually settled on a SolarEdge system consisting of 4.8kWh panels with optimisers, SolarEdge 5kWh hd wave hybrid inverter/ EV charger & 10kWh battery. I’m not interested in off grid support for power failures but this could be added if necessary in the future.
Ignoring the minor tribulations for lack of stock & moving installation date the installer/supplier has been really good, always available & quality installation, so no complaints.
The SolarEdge system has a versatile configuration for hourly hour, day by day, week by week, month by month & season set up, consisting of a number of profiles.
This is where the problems started. I’d downloaded the manual for setting the various profiles & worked out what was required, then discovered you don’t set the profiles yourself, your installer or tech support do.
Simple really, solar runs the house, excess to the battery then EV/ water heating etc. when solar not available the battery runs the house.
In winter months charge the battery using off peak TOU energy.
Hopefully reducing export to a minimum and import peak rate to zero.
Initially (late May) all excess went to the grid & ignored the EV so a call to tech support.
A WhatsApp chat commenced with me explaining which profiles I wanted & bingo 2 days later a working system, so I thought. Lots of solar energy, a full battery & house running smoothly.
The evening prior to a weekend away on the south coast I scheduled the EV to fully charge by 10.00 am the following morning ready for departure.
The schedule didn’t happen & my EV was still at 62%. Not a disaster but very annoying. Scheduling the the tesla app has never failed in over 18 months, the first via SE, failed.
I initiated a manual charge to discover that the SE battery was also discharging into the EV, not what I expected or wanted.
On my return I also noticed that between midnight & 6am the house ran off the grid not the battery, consuming just under 2kWh, half peak & half off peak.
Another WhatsApp chat revealed the SE battery will always discharge when using EV boost charge, ok I’ll live with that now I know.
The night time grid consumption was due to an incorrect time setting for the profile, yes fairly obvious so I again detailed the profiles I needed.
So two days ago I finally received a email at 08.05 confirming my summer and winter profiles were now correctly set up. Excited I opened the app (08.11) to find 68wh generated & now ZERO output, battery at 97%.
Another whatsapp call, responded to 4 hours later & another hour + checking the system they tell me my inverter looks like it’s failed & I should contact my installer to arrange a warranty replacement.
So no SolarEdge generated power, no EV charging & days of perfect sunny days to come.
My installer ( most apologetic) ordered a replacement inverter (estimated 2-3 week delivery) + installer availability.
I got back on to SE support explaining I now had no way of charging the EV, what were they giving to do.
A couple of hours later a email asking me to try a charge which worked, so not a total disaster.
Although a long thread I have spared you some of the detail as this fiasco has been going on throughout June, July & August.
Simply put, the system when working is very good but tech support is almost none existent in terms of their ability to get things right. I suspect untrained staff who don’t understand the system they are supporting.
SO BEWARE if purchasing a SolarEdge system.
