Thanks for passing along the issues with DC measurement. There is a junction box in the attic, so I assume the leads feed in there and then down to the inverter. I was going to take a look at it. Hopefully, there will just be
some terminal lugs I check with a probe.
To measure current with a probe you need to break the circuit and have all of the power flow through the meter. So if there was a lug there you would need to disconnect it, then connect the wire to one probe and connect the other probe to the lug. With the amount of voltage and current that we are talking about, this is probably not something you want to be doing. Using a clamp on meter would be much safer and easier.
We have multiple inverters. One is 8Kw and the other is 4Kw. I believe the 8Kw is for the south-facing and one north-facing strang, and the 4 kW is for the other North facing. I have done the really basic test and shutting them off one-by-one. In both cases, there was a drop when I shut one down and restoration when I brought it back on-line. So I think that at least at that the basic level the inverters are working.
Do you have any way to see how much each inverter is generating? With a screen on the inverter or connecting your phone to it or anything?
I suppose you could still see how much each inverter is producing on a sunny day by shutting off the 4kW inverter. On a bright sunny day, note how much power you are producing before you shut off the inverter, then note how much it drops after it is shut off. That is the amount of power the 4kW inverter is producing. Then note how much power is being produced while the 4kW inverter is off. That’s how much the 8kW inverter is producing. If it looks like the 8kW inverter is producing 6 or 7kW and the 4kW inverter is producing 2.5 or 3kW then you’re probably good. If you’re only getting 3kW out of the 8kW inverter then that’s probably worth investigating further.
Actually, maybe the better place to start would be using an AC clamp meter to measure the AC current coming out of each inverter. Again, I would suggest doing this on a bright sunny day, but open your electrical panel and use the meter to measure the current from each inverter. Again, remember that you need to isolate a single wire, so pick the red or the black wire. That will give you the number of amps that the inverter is producing. Watts = volts times amps, so take that number, multiply it by 240V (or actually measure your voltage with your meter for a little more accuracy). Then divide it by 1000 to convert from watts to kilowatts. Again, if both inverters seem to be producing at about the same capacity, then you’re probably good. If one is producing at a significantly lower capacity than the other then you might want to keep investigating.
Did anyone get some sort of string to inverter wiring diagram from Tesla?
I don’t have a solar roof, but the electrical drawings submitted to my city for my permit did show which panels would be connected to which inverter in my case.
