Solid blue
Discussion in 'Model S: Battery & Charging' started by aollivierre, Sep 5, 2018.
  1. aollivierre
    aollivierre Member
    arlington,tx
    Got a solid blue light. What does that mean? The car is uploaded.
  2. ewoodrick
    ewoodrick Well-Known Member
    Buford, GA
    The taillights turned from red to blue?
    There are a lot of lights on the car, which one are you referring to?
  3. aollivierre
    aollivierre Member
    arlington,tx
    Charge port
  4. MathijsKok
    MathijsKok Member
    France
    If the cable is inserted it means that the port is ready to receive electrons.
  5. scottm
    scottm Version 9 software sufferer
    Canada
    Dark blue means, "charging is stopped and the car is locked and the port flap is open".
    What do you want to do next?
    A. Charge the car: I would close the flap and re-open it using the button on the cord, then plug it in.
    B. Unplug charge cord if it's plugged in: unlock the car from the fob, press the button on cord, pull it out.
    C. Drive if already unplugged: close the flap, get in and drive.
  6. Rockster
    Rockster Active Member
    McKinney, TX
    I thought blue meant that everything was okay but the charge simply hadn't yet started because scheduled charging had been specified in the car's settings.
  7. scottm
    Canada
    Yup. That too.
    Hasn't started yet, or is finished. i.e. "not currently charging" is blue
  8. Rocky_H
    Rocky_H Active Member
    Boise, ID
    Yes, that basically indicates:
    1. It is plugged in
    2. It is not currently charging
    3. Everything is fine
