Solution for amateur radio operators? Impossible to use magmount antennas in a Tesla
Big Toys
557
462
Florida
Interesting to see so many hams. I've had my license since the late 70s, but haven't played with it since the early 80s. I even ran an antenna from my dorm window to the adjacent building, and it took a long time before it was discovered. Ha! Although, I never figured out what to talk about beyond location, rig and weather, and with school being priority I haven't touched it since. I still have my old Kenwood Twins and an older radio in the attic somewhere; my first key, and my mechanical bug on my bookshelf.
Reactions: beeeerock
SteveQLQ
10
2
Boynton Beach, Florida
Yes, I intend on having enough slack in the wires to enable the cubby to be dropped and the control head is very light so a Velcro strip would hold it in place. Still have to figure out how to run the wires from there to the rear.
beeeerock
1,500
426
Kamloops BC Canada
I can relate. Licensed in '78. University and I also managed to get an antenna up (down!) from the 6th floor to a couple of trees. Thin wire - it lasted the full 8 months I was there and nobody apparently found it during that time. Point Grey, UBC, in Vancouver. Over the ocean - it was the best location I ever had and I worked the world from there. Haven't been active since the late 80's, but still have the 520 and 830 boxed up in the basement... just in case... ;-) And yeah, my Vibroplex sits on the window ledge in my den... LOL
rooter
673
840
Edmonds, WA
When I was in the Service in the '70's I listened to alot of shortwave radio in East Germany. The BBC with their pompous theme song, "BUMP BUMP BUMP BUMP"...
Once I caught little Radio Albania in their hour broadcast in English, about "Applying Marxist Principles to Physical Education", lol. Fascinating.
Big Toys
557
462
Florida
Ha, that's funny, I thought I was the only one stringing wire out a dorm window! Yep, it was a braided or twisted copper wire, must have been end-fed, I can't recall. Strung it to a stairwell window in the opposite building. Could hardly see it, or no one cared. I took it down when I figured I had to study. I pulled out the bug to show my daughter what we used to do before video games and social media.
Brand new. Just picked up my Model X, got hit by a deer within a week. Next got my wife's Model Y. Still trying to figure out where to mount EZPass in X, after wrapping and filming everything. How to get Sirius in Y, or even what all-weather mats to get for Y.
Meanwhile, have Cobra CB and Kenwood ham radio, off my old FJ Cruiser, now collecting dust in garage. Toying with idea of mounting ham radio, and was just going to plug into one of the cigarette lighter sockets. Bad idea?
And then mounting the antenna. What "road blocks" should I realize might be insurmountable?
Waited through factory closure for delivery. Spent over a week wrapping, in satin finish, changing wheels, etc., then FINALLY got to drive it. Few days later, wiped out by deer. Been in repair shop for a month, who say when they do get around to me, it will be at least another month.
Looking for best deer whistle also!
cruiserlarry
Gadgetologist
Jan 24, 2017
275
328
Los Angeles, CA
As a active ham radio operator / disaster comms volunteer, Tesla Model S, Model 3, and FJ Cruiser owner, I'll give you my two cents.
Mobile ham radios (and virtually all 2-way radio systems) should always be connected directly to the 12-Volt "cranking" battery (for Teslas its the aux battery) - never through the 12-Volt power sockets. The radios usually draw more amps when transmitting than those sockets can provide, and require more robust wire size and fused ground wiring to work safely. The bigger issue is mounting the antenna on the X since the body is not steel, and there is no good ground plane to work with for most portable antenna systems. You might be able to mount a Diamond lip mount to the frunk, but you may also damage the aluminum sheet metal from the weight / movement of the antenna itself. There is also a very small possibility the radio will interfere with vehicle electronics when transmitting, depending on the output power and antenna location, which could be dangerous. The Model Y uses standard steel body panels, so mounting might be easier. I suggest you contact someone with direct experience on the Tesla - maybe Ham Radio Outlet, or similar specialist - before installing the radio in the X or Y.
So the thought had crossed my mind to install my HAM radio in my new Model X. From what I am hearing:
* Electrical draw, especially on transmitting, requires being wired directly to the 12VDC battery, not to either cig socket (that would have been be far too easy).
* If a non-factory electrical draw occurs from the 12VDC battery, that might possibly create a system "inquiry".
* Need to find apparent ground point.
* There is no good ground plane.
* Mag mount not possible since body panels are aluminum.
* Without drilling any holes, and no mag mount possibility, an antenna lip mount might work, but over time, could easily bend that lip.
* There could be interference with the vehicle electronics when transmitting.
Other than that, should work fine. Any one want to buy a really nice Kenwood VHF/UHF radio?
Thanks for everyone taking their time to offer advise.
73, Burton, W3HFX
stanrock
New Member
Jul 18, 2019
2
0
Ann Arbor, MI
I have a 2018 Model 3SR. I installed a Icom 880D 2M/440 radio which is plugged into the DC Power Jack. The current draw on high power transmit is never a problem. I have a trunk mount antenna with very good SWR.
The main problem with the Model 3 is the level of RFI on 2 meters. It makes it nearly unusable. I am getting S7 to S9 on some of the repeater frequencies. I tried to connect my ICOM directly to a external AGM battery, but it doesn't make any difference; The noise is still there. In addition, I like to monitor aircraft bands, and it is nearly impossible as well.
I have tried mag mount antenna, isolating the antenna from the body, different antennas. Nothing seems to help. The model 3 is a noisy beast on 2 meters..exactly the band I want to use!
As a last ditch effort, I will try a glass mount antenna on the small window.
Ham radio is alive and well here in Michigan. We have more than a couple weekly nets and before the pandemic the morning drive was very active on the bands. Its a great hobby for a techie!
lascavarian
921
4,902
usa
Ham radio has been a great hobby during the pandemic but poor band conditions at the solar minimum. I have done some AREDN signal hunting in my '18 model 3 but didn't work particularly well. I am encouraged that there are police versions coming out which tells me noise issues must be workable on some levels.
My question would be can you tell a difference on 2m between the the 3 powered up vs sleeping. I guess this would take an HT or SDR to get some data.
I have a CT on order and that is where I am really interested. That should be interesting for FD come about 2022. Last actual FD our club operated I slept for a few hours in the 3 with the AC running and it was great.
BigTonyTones
626
517
Los Angeles
Another AREDN user! Nice to meet one on the TMC forums!
