Solution for easy and convenient maintenance of tire pressures at home
Discussion in 'Model S: Driving Dynamics' started by artsci, Dec 1, 2014.
  1. artsci
    artsci Sponsor
    Timonium, Maryland
    After installation of the FoboTire pressure monitor system for smart phones I began looking for solutions for checking and inflating my Model S tires without having to make a trip to the nearest gas station (ugh) with free air (very hard to find these days) or using a lighter socket powered inflator. I was hoping to find a cordless inflator that would read the pressure at the same time it was inflating the tire. I also wanted to take readings before any driving warmed the tires (yes, I'm a total fanatic about maintaining correct tire pressure).
    Sears to the rescue. There I found the Craftsman 19.2 volt cordless inflator, which enables setting the desired pressure and automatically stops pumping air when it's reached. It has a digital gauge on the back that reads the pressure as you inflate the tire.
    I tested it this morning. Using the the inflator I set all of the pressures to 44 psi then used the Fobo monitor to test its accuracy. The Fobo recorded all four tires at + or minus 0.3 psi from the 44 psi seeing. That's incredible accuracy. This tool will be kept in the car at all times.
  2. Madartist
    Madartist Member
    Florida
    I've been using this Craftsman system for years. It works very well.
  3. artsci
    artsci Sponsor
    Timonium, Maryland
    I'm amazed I didn't know about it -- I just didn't look hard enough.
  4. JakeP
    JakeP S P4996 / X P6028
    Wexford, PA
    That is incredible, what a great find. Especially handy here in PA, where we have seen 30 degree temperature swings every week for the past month, it seems. Something for Tess's Christmas list!
  5. Madartist
    Madartist Member
    Florida
  6. pgiralt
    pgiralt Supporting Member
    Cary, NC
    Thanks for the tip. This is perfect! So much more convenient than the plug-in pump and manual pressure readings. Will come in handy for inflating bikes too.
  7. jayman
    jayman Member
    Illinois
    That is awesome. I'm buying one
  8. AnOutsider
    AnOutsider S532 # XS27
    I've been looking for something like this and have a bunch of sears points to spend. Perfect!
    No kidding! I'm glad our local Wawa followed Sheetz with the free (and digital) air stations.
  9. SteveW25561
    SteveW25561 Member
    Vancouver, Canada
    #9 SteveW25561, Dec 2, 2014
    This looks like a great tool. Unfortunately the linked tool doesn't come with a battery so you'd also have to buy the battery and charger for this Sears tool.
    I did find what looks like a very similar tool -- the Airman air gun. The plus is their kit includes the battery and a 12 v adapter to run if your inflator battery is dead. The downside is it's just a 12v battery so not as powerful as the Sears one, I'd bet. This makes me wonder if it's up to the task. The airman website does mention its application for car tires.
    I found it for about $70 at Airman AirGun Professional LED Sports Inflator # 55-032-021 - Rakuten.com
    Any opinions on this tool vs the Sears one?
    The other 20v tool is Sears version of the Black and Decker Matrix drill with different attachments. I have the exact inflator attachment for it, but haven't tried it on my car yet.
    Just this weekend in the cold snap I got a low pressure warning and had to find a gas station to fill the air! I do have an emergency tire slime kit but it's a pain to haul out so I like the idea of a portable device.
    Thanks for the tip, Rick!
    Edit: it looks like the Airman I suggested isn't likely up to the task -- their own website shows a check mark for small cars but not for midsize or large cars, so I guess it's the Sears tool. Sorry for the initial confusion. I was excited to find an alternative.
    http://my-airman.com/product/which-airman-is-right-for-you
  10. Andyw2100
    Andyw2100 Supporting Member
    Ithaca, NY
    #10 Andyw2100, Dec 3, 2014
    OK, so I ordered without noticing it didn't come with the battery and charger. While I'm sure I could easily cancel the order, I still want the unit. I just looked into battery and charger options, and I am somewhat confused.
    It would appear this battery and charger would work, and costs about $70: Sears.com
    But isn't this the same battery, with a different (less powerful) charger, for $50, and with a drill included?: Sears.com
    I just want to make sure I don't make another mistake.
    Thanks.
    Edit: Actually this Sears.com seems like a much better drill for $80, which is $10 more than the battery and charger by themselves, but I think this charger is almost as good as the charger that comes in the $70 set speed-wise (one hour charge vs 30 minute charge), plus you get a drill. And this one can ship to me, while the one above can't be shipped right now. Am I missing something, or should the drill/battery/charger combo linked in this edit work just fine with the inflator I already ordered? Thanks!
    - - - Updated - - -
    By the way, Ebates is doubling their Sears rebate from 3% to 6% today, and there's also free shipping (from Sears), so you can save 6% on this stuff through Ebates if you order online.
  11. artsci
    artsci Sponsor
    Timonium, Maryland
    #11 artsci, Dec 3, 2014
    It does not come with battery and charger and buying those about double the cost. You're right about the drill and battery -- it's the same battery.
  12. bollar
    bollar Disgruntled Member
    Southlake, TX
  13. AnOutsider
  14. bollar
    Southlake, TX
    Yes, it does. You can set to 1 pound increments and it measures to 1/2 pound increments.
  15. JKW
    JKW Member
    Colorado, USA
    Just ordered one, thanks for the tip
  16. GetAmped
    GetAmped Member
    Toronto, Ontario, Canada
    Another inflator worth checking out is the "Ryobi One+ 18-Volt Cordless Green Inflator" this is available from Home Depot and includes a built in battery and charger. I am picking up one tomorrow to be ready for my P85D so that now I can avoid gas stations.
  17. tdiggity
    tdiggity Member
    Bay Area, CA
  18. Vitaman
    Vitaman Member
    Decatur, GA
    Been using 12 volt plug in type....the cordless looks way better.
    Thanks for posting!
    Ordered the 19 volt Craftsman system (inflator, battery and charger). Came out to about $120. Pricey but worth it to me for the convenience and peace of mind.
  19. Andyw2100
    Ithaca, NY
    For artsci, madartist, or anyone else who has one of the Sears inflators...
    I bought one too. (See my posts upthread.)
    The first one came some time ago, before I had my Model S, and when I tested it I found that while it worked well, the pressure readings it gave when just giving readings were about 1.2 to 1.3 PSI lower than the readings it would give when set to inflate to a set pressure. So, for example, if set to inflate to 45 PSI, it would slowly read up to 45 PSI, then shut off when it reached 45 PSI, and then immediately show 43.7 PSI or 43.8 PSI. I called sears to confirm that I wasn't doing anything wrong. They said I wasn't, and that I must have a defective product, and that I should send it back, and get another one. It has taken quite a while for Sears to get me a replacement, and I just tested the replacement a few minutes ago. It turns out the replacement behaves the exact same way!
    So what I am wondering is how do yours behave?
    In the original post, you stated, artsci, that you compared the inflated PSI to the reading you received with your FOBO, but you never said that you compared your inflated reading with a reading from the inflator itself. I'm wondering if I should try to get a third unit, or if they are all going to do the same thing. I can live with this if I know one of the two numbers is accurate. I just ordered another digital tire pressure gauge, in an attempt to be able to tell which, if either, number is accurate. I bought this: Amazon.com: TEKTON 5941 Digital Tire Gauge, 100 PSI: Home Improvement
    If someone who has this Sears inflator could tell me if yours shuts off at a given pressure, and then immediately gives that same pressure as the reading, that would be very helpful to me. If several of you say yours work that way, I guess I'll be sending this one back too, in hopes of getting one that works properly, the way yours work.
    Thanks!
  20. N4HHE
    N4HHE Member
    Madison, AL
    Those have been on/off the market for the past 10 years that I know of. Very handy for inflating dirtbike tires.
