  • We are looking for another podcast participant who can act as a lead co-host to join the TMC Podcast. If you are interested in participating please see this thread.
Solved: Road Noise & Front Wind Noise
Through the last few months, I have been watching and reading up the various posts regarding the many ways many of you all have attempted, as well as the various kits available online, to reduce if not eliminate road noise and wind noise from the Model3. After reviewing all those posts and review of the kits, I figured that since none of you have been able to achieve that elusive goal, let alone even come close to reducing the noise, made me ask the question: What are we missing?
So as I kept driving my M3, I attempted to focus on finding those missing sources ie where is the noise emanating into the cabin from. Turns out they are the 4 corners of the cabin ie the A-Pillars and C-pillars. More specifically, the A-Pillars for wind noise and C-Pillars for road noise.
#1 - The solution for wind noise is the following - Z Weatherstrip down inside the leading edge of the front door, and foam block at the top triangle where the front fender, windshield and door meet.
Z-Weatherstrip
Foam at the junction
#2 - The solution for road noise is the following - 2" Fiber insulation behind the rear seat side panels that cover the rear wheel wells.
I hope this helps everyone who have been pursuing this goal. Thanks for all the contributions and many thanks to @XPsionic for his constant engagement and interest.
enemji
1,186
1,001
Dallas, TX
Yes we cannot wait 😅
So I went ahead and ordered a decibel meter for this purpose. It is the Protmex 1-HT602A Sound Meter from amazon.
Initial results are in. Tires are Kinergy GT 18" at 41psi
City roads at 30mph - 62db
City roads at 45mph - 65db
Smooth new concrete highway - 66db
Rough worn concrete highway - 69db
As a reference, why don't you guys go ahead and measure your unmodified vehicles to compare?
You really need to remove all your foam and insulation and measure again, for science!
Reactions: enemji and Adam3
Oops. I forgot to mention the highway speed
Smooth new concrete highway 80 mph - 66db
Rough worn concrete highway 80mph - 69db
It's likely most of us won't have access to high quality calibrated equipment like this. It might actually be better to use our own smart phones to measure noise and just state what phone was used and to pick some app that's available on both iOS and Android. That way we can get an idea of relatively how much better the noise suppression is. A calibrated db meter will give us an absolute picture but most of us lack the equipment.
Reactions: ICE5891
enemji
1,186
1,001
Dallas, TX
My fear is that the built in phone microphone is probably designed to capture human voice…. I maybe wrong.
It might be better suited for voice but atleast we can rely on everyone having similar hardware for their measurements so we can get a relative picture between cars that have modifications and don't. You are correct that a calibrated dB meter will give a better picture on the absolute noise levels.
Reactions: enemji
enemji
1,186
1,001
Dallas, TX
Reactions: zoppp
Glad you made a thread with the solution, hopefully people searching with the right keywords will come across this and find it useful! Much easier than digging through 10 pages of discussions.
I just want to add that the foam used in #1 is Siless liner 157 4mm thickness dense closed cell PE foam, 18 sq ft should be enough. And for #2 the material used is Kaowool ceramic fiber fire insulation 1"x16"x48", cut to required size.
Thank you very much for this information
Reactions: enemji
Z-Weatherstrip
Thanks for info. Greatly appreciated
How do U know that U have problem?
How do I know that I have the same problem?
