Some details of new battery at WSJ article
Discussion in 'Battery Discussion' started by ivengo, Jul 24, 2016.
Tags:
  1. ivengo
    ivengo Member
    Texas
    Here is a new article from WSJ that talks about gigafactory and has dimension details of the new and old batteries
    Tesla Races to Finish ‘Gigafactory’ in Time for Model 3 Rollout
    When you read about the details of the battery you will encounter the following paragraph
    "Tesla’s gigafactory will be the first ever to make a new format of battery—a 21/70, rather than the 18/650 that the auto maker uses today for the Model S and Model X. The latter cylinder-shaped battery is commonly used in portable electronics and has been used by Tesla since the beginning. The numbers stand for the width and length in millimeters."
    The dimensions of the old battery 18/650 dont make sense, because 650mm is a couple of feet long which is in no way will fit model s or x floor. I thought it is a typo first but the author uses exactly the same numbers in the comments section.
    Do you know what is the actual size of the "old" cell?
  2. Cyclone
    Cyclone Cyclonic Member ((.oO))
    Charlotte, NC
    Should be available on listings for purchase of an individual cell.
    Amazon.com: 18650 battery panasonic: Electronics
  3. AndreN
    AndreN Member
    Redmond, WA
    18650 cells are 18mm x 65mm. No idea why WSJ is calling them 18/650. No one does that. Also the 21/70 would be called 21700.
    From Wikipedia: "The larger rechargeable cells are typically assigned five-digit numbers, where the first two digits are the (approximate) diameter in millimeters, followed by the last three digits indicating the (approximate) height in tenths of millimeters."
  4. Johan
    Johan Funds for M3 secured. Contingent on wife aproval.
    Drammen, Norway
    Well there you have it: WSJ is as clueless when it comes to battery dimension nomenclature as they are to everything else Tesla related.
  5. ivengo
    ivengo Member
    Texas
    Thank you for your replies, they are very helpful.
