Thinking about trading my 2020 LR Y for a 2022 Y Performance and have some questions for people that recently took delivery, like May, June, July time frame…. Could you also add the approximate VIN range you are
I know anything can change at any moment, but just trying to get a feel of what the last 60 to 90 days has been like…
Are you CCS charge support enabled?
Do you have heated steering wheel?
Do you have the AMD chip for the MCU?
Matrix headlights?
Do you know your actual battery capacity? (ScanMyTesla etc, I believe Performance vehicles used to be about 82kWh)
Then some general build quality questions. I guess I'm less concerned about panel gaps, I had a 2019 Model 3 and now a 2020 Model Y, I know the panel gaps and can live with it... BUT, rattles and creaking sounds drive me insane. I know the center console is a big area that creaking sounds can come from (you can lean your leg against the console and the sound will stop, etc) and the rear seats often make some rubbing/creaking sounds.
Finally, anyone know if 19" Gemini wheels still fit on the Performance cars? I have a set with winter tires on that I would ideally like to keep using...
Matrix headlights?
