Some thermals of my Model X
Discussion in 'Model X: User Interface' started by Dazureus, Mar 31, 2016.
  1. Dazureus
    Dazureus Member
    Michigan
  2. K-MTG
    K-MTG Sunshade Captain of TMC
    Irvine, CA
    Can you make the video unlisted or public? We can't watch them
  3. Dazureus
    Dazureus Member
    Michigan
    Sorry, three of them weren't published. Working now?
  4. K-MTG
    Irvine, CA
    Yup, thanks
  5. elguapo
    elguapo Member
    Maryland
    @Dazureus To me, the cool down video shows the ventilation really doesn't work, as others, including me, have reported. I don't see any real airflow in there or meaningful cooling.
    That said, there's just supposed to be ambient air, so it shouldn't really be cooling, but you should see airflow and I don't really see that. It's on my list for the SC.
  6. Dazureus
    Dazureus Member
    Michigan
    It is just ambient air and there are two factors at play in my video. 1: This is a "cool down" right after a short heat up, so the heating elements are still dissipating heat. 2: the ambient air temp was only 10 degrees F cooler than the heated seat so the coloration gradient used to show temperature was that great. If you compare the beginning of the video to the end, you can see where the greatest areas of temperature differential are. This thermal camera displays more on temperature difference in the viewable area rather than absolute temperature to color equivalence. I think the software can set coloration cut offs so I'll play around with it and post the results.
