Dan D.
Desperately Seeking Sapience
You chose to buy Elon's car==Input. Almost All User Input is Error. ∴The car decides from now on.That could be explained by an entertainment, rather than driver focus. Did we buy cars or game consoles?!
Unfortunately this doesn't work with mine. No matter where or how much I click, drag or swipe, there's simply not the reaction shown in your example.The progress bar is still there. The target area for dragging the progress bar extends between it and the buttons above - plenty of area to drag or tap.
Exactly this.It worked just fine with the dedicated button - not only for control but also for indication. It is not impossible in V11; it is more complicated and I do not see the benefit of making it complicated - unless, for some reason, they want to discourage me from using it.
- the ’cluttered interface’ wasn’t a problem before, especially the row of buttons on the bottom. Adding blank space isn’t an improvement and is solving a problem that didn’t exist.It's readily available still. The interface is now less cluttered, and things are logically grouped together.
It was more “readily available” in V10.
The fact that something critical is “still available” or “there is a voice command” does not mean that it is an improvement from a driver-centric, functionality point of view. If the objective is to have minimum number of buttons/icons on the main screen - may be they achieved something but, still, there are a number entertainment icons left. Why did they de-grouped them and grouped the functionality icons? That could be explained by an entertainment, rather than driver focus. Did we buy cars or game consoles?!
Other than radio stations now and then I mainly use Spotify for most of the time.My example was a podcast. Perhaps there is different behavior on other sources - I’ll have to test. What source were you using?
Critical controls are anything but subjective. The car is certified for all seasons, so both windshield wipers and defogger/defroster are critical systems (seat heaters are not).
This!Critical controls are anything but subjective. The car is certified for all seasons, so both windshield wipers and defogger/defroster are critical systems (seat heaters are not).
Exactly, one tap more than necessary. Plus for the second tap you now have to look down to find the defogger or defroster or heated seat buttons among the now cluttered and complicated climate control mess.Fair enough. If I ever need the defrosters, they're 2 taps away.
Yes, but not everyone wanted or needed all those settings on the bottom bar. And it's a huge exaggeration to think 2 taps vs 1 is going to make any meaningful difference to a system that takes a lot longer than 2 seconds to do its job. Sure, the wipers were out front, but it still required more taps than the current setting, so where was the advantage? Also, the defrost icons were almost all the way to the right. How was that convenient? Most drivers would have to look to the bottom right to accurately select them.Exactly, one tap more than necessary. Plus for the second tap you now have to look down to find the defogger or defroster or heated seat buttons among the now cluttered and complicated climate control mess.
Again, why? Why make something MORE COMPLICATED than it was? Where the heck is the improvement?
Just look at the screencap of the old UI you posted yourself. It's sleek, clean, and very easy to use intuitively. Everything vital is accessible with a single tap. Even if you don't need the seat heaters, or defroster or defogger, having the controls directly available doesn't take away anything.
And before they were one tap away. In an easier location (at the edge of the screen vs in the middle.) And you could see if they were on or not.Fair enough. If I ever need the defrosters, they're 2 taps away.
