Sound Deadening Model 3
dfwatt
2,910
4,935
FL
Yeah testing after each change would have been cool to know what made what difference.
Yes for sure that would have been a better method. But I was going to do all that stuff anyway because it was cheap and I had done it before on other cars so I was just taking a shotgun approach to killing every possible source of noise I could think of. There was probably more work than a scientific approach but it was effective because the car is now significantly quieter on the highway. Others have done scientific testing on some of what I did but I don't believe anybody has done a scientific measurement of Dynamatting of the doors or the trunk area. But there are measurements on the door seals and the neoprene tubing around the glass. Don't have those Links at my fingertips but I know there's threads on both of those two on this forum.
BioSehnsucht
Model 3 LR
Apr 1, 2016
1,787
4,800
DFW, TX
I used two different types. I used the RPM Tesla wind noise reduction kit which is basically hollow neoprene tubing that just wraps around the roof glass and then I used some solid .25 inch tubing to fill the other channels that I got on Amazon called "trim lok cord stock rubber seal tubing." The solid tubing filled in gaps where the RPM Tesla kit couldn't. Combination made a significant difference. Others have measured this at something like 3 DB noise reduction. RPM Tesla claims 5 to 8 DB noise reduction just for their kit alone without the supplementing that I did. I think this is generous, but for sure this is a fruitful issue to address, and you can make a significant difference for little money spent.
Did you layer the RPM kit and the other tubing, or did you use the tubing in the places the RPM kit didn't reach? I have a similar kit to the RPM kit (got it off amazon) and it hasn't made any noticeable change on it's own (though I mostly hear wind noise from the passenger A pillar area, rather than the glass roof itself - it's possible it made an improvement but it's drowned out by that wind noise)
I also have one of the door seal kits, and that did make a difference in road noise. It also really tightened up the sub bass, to the point I wish the sub had it's own EQ, separate from the rest of the speakers.
dfwatt
2,910
4,935
FL
A little bit of both. The RPM Tesla kit tubing compressed so easily that it didn't really fill the space in the back of the roof window glass so I doubled it up there and then ran the solid tubing down the length of the rear window as well. Then I ran two separate strips on the front window up to the beginning of the roof glass. So in some instances the solid tubing was placed on top of the easily compressible hollow neoprene tubing that was just on the center roof glass piece. In other areas it was only the solid tubing. The end result was that there was really no Gap to excite any kind of resonance from air passing over it.
Reactions: BioSehnsucht
cab
1,029
714
Grapevine, TX
We should begin seeing the "sound deadening my Model Y" threads soon enough! Interestingly, the Model Y doesn't show to be able to tow, but the manual appears to show that restriction as "coil suspension". This makes me wonder if towing will be tied to the availability of air suspension (since the latter can level the rear when additional tongue weight is applied). This and the "leaked?" air suspension stuff in the online catalog give me hope that we will see it (in the model 3 too) AND that the air suspension will help to reduce NVH in these cars.
PNWLeccy
846
677
Seattle
Towing is supposed to be available in the EU M3. At least I believe that was announced in 5/19 but haven’t seen anything since and I assumed air suspension was not planned for M3 according to Elon
cpxasn
38
10
Atlanta, GA
What tools are guys using to remove the bolts from the front seat rails?
T47 torx bit is too large, and I stripped those bolts in the past with T45 and had to pay $120 for Tesla to remove them.
mtndrew1
1,312
3,677
Gardena, CA
I installed the trunk liner sold by RPM Tesla and many online distributors (they all appear to be identical) and it made a significant reduction in noise from the rear of the car.
Mind you my car has the “hole” style rear parcel shelf and there was a ton of noise radiating through that opening. It’s much quieter now, well worth the $75.
Reactions: Adam3
PNWLeccy
846
677
Seattle
Interesting because I did not notice any change in noise- do you have any before and after dB readings?. I just bought some sound deadening to apply under that trunk area and properly close the hole before covering it again with the trunk liner mat. Hopefully that will help for me.
Reactions: Dayreg
mtndrew1
1,312
3,677
Gardena, CA
I did not take any measurements but I don’t think it’s placebo effect because now I notice wind noise around the front of the car as the primary source where before it was the roar from the back.
Could be my specific roads or the fact that I have a very early car, but I do notice a difference and feel it was worth the cost. It also looks nice but that’s not why I bought it.
mtndrew1
1,312
3,677
Gardena, CA
Someone here mentioned they have an early car and a later 2020 model.
Could someone who fits this description confirm or deny any differences in factory side glass window seals and if there is one, post some photos?
I am willing to buy the 2020 parts and install them if they make the car quieter.
TLLMRRJ
1,641
1,611
Houston
This is what will make your car super quiet
Model 3 & Y Road Noise Reduction Kit -Gen. 2 (10 Pieces 2 Trunks) $45 w/ 20% Off
My car is so quiet now. 100% worth it
Now that rubber strip for the roof, not worth it
I recently installed that kit after waiting nearly 4 months for RPM Tesla to ship it to me (and that was with their extra-cost expedited shipping service). Complete worthless. Zero change in noise, and I used the same phone/app for before and after dB tests. And it just doesn't sound any quieter.
I just ripped the trunk seal off because it was making the trunk really hard to close even after letting the seals settle for a couple of weeks.
And the adhesive is super low quality. I was very careful to clean the surface with 91% IPA and then use their adhesion promoter and I have a couple of the seals already coming off. I can tell a good quality adhesive from garbage, and this one is garbage.
Plus the seal design on the front doors does are not properly designed to seal the lower part of the trailing edge of the door, so plenty of dust and water can still get into the door jam area.
It's not a big cost, but it is a time suck for zero gain. Don't bother.
Zcd1
688
792
Chicago area
I used 2 different types of seals bought off of Amazon (Prime 2-day shipping) and noticed the difference in road/tire noise right away.
Didn't make the doors more difficult to shut in my case, but did make them sound better when being shut.
Well worth the $35 and 30 minutes, IMO. (shrug)
PNWLeccy
846
677
Seattle
Why 2 different seals? Did you get D seals and B seals rather than a kit (basenor, rpm, goloho, etc. )?
TypeRx
415
270
Orange County, CA
I bought P and Z seals from the good 'ol Bay but in hindsight, just wish I bought the Basenor or RPM kit from the get go. I'll probably swap over at some point. I bought them less for noise reduction and more to keep things clean (can't stand the dirt buildup in the door keeps, etc.).
