Sound deadening work begins next week: will report before and after data
Discussion in 'Model S: Interior & Exterior' started by artsci, Aug 14, 2014.
  1. artsci
    artsci Sponsor
    Timonium, Maryland
    On Monday I'm dropping my Model S off at Don Sambrook's shop in Manchester, Maryland for him to begin work on sound deadening the car. Don is one of the top experts in the field and I'm very fortunate that his shop is only 20 miles or so from my home and that he could even take me as a client (he works himself on only 2 or 3 cars a year). Don's website is a source of incredible depth on sound deadening techniques and materials but this will be the first Model S he's evaluated and done. He teams up with Bert Miller on all of the installation work. Bert's expertise is doing all the the tear downs of the interior that are necessary to do the job the right way.
    Between now and then I'll be taking and saving a series of sound measures to record the sound levels on my drive to and from work every day. The route has a great mixture of road types with different surfaces — two lane country road with some speed bumps, busier two lane road, four lane, Interstate, city streets, and parking garage. So I’ll have some very good before and after measurements for comparison of results.
    When the work is finished at the end of next week I'll take new measurements along the same course and post the comparative results.
    Yes, I know the car is pretty quiet as it is, but this was inspired by my friend, SUPRKAR, who sound deadened his entire Model S over a period of 3 months. He told me the results were astounding -- it was like having a different car. He did all of the work himself. Although I intended to do this myself as well, when I looked carefully at what would be required I concluded that didn't have have the time or adequate work space to do it all. So I was fortunate to find Don, whose rates for both labor and parts are very reasonable.
    I'll report back when I deliver the car to Don next Monday.
  2. omarsultan
    omarsultan Active Member
    Northern California
    I'd also be interested if there is a material affect on range/efficiency. I sound-deadened a MB SUV a while back--did the work myself. One things that I remembered was the weight of the sound deadening materials.
    O
  3. artsci
    artsci Sponsor
    Timonium, Maryland
    It will add some weight but Sambrook tries to use as many lighter weight materials as possible. Plus range never an issue for me anyway.
  4. lloyds
    lloyds Active Member
    Bay Area
    Do you think it will help with noise transfer from the tires?
  5. Raffy.Roma
    Raffy.Roma Active Member
    Rome (Italy)
    I saw once a video of the Model S inside the cabin while running and the noise inside the Model S was really negligible. So I wonder why to deaden sound inside the cabin of the Model S?
  6. artsci
    artsci Sponsor
    Timonium, Maryland
    Most of what I hear is road and wind noise, and at speed it's pretty annoying, made worse by the fact that there's no engine noise to mask it all. So the wheel wheels and front and rear trunk areas will be a focus. Based on SUPRKAR's results, substantial improvements can be made.
    - - - Updated - - -
    Not the case at speed. Some ICE cars are as good or better, which shouldn't be the case. So I think Tesla did not pay enough attention or put enough resources into noise deadenig.
  7. rcc
    rcc Model S 85KW, VIN #2236
    San Jose, CA
    Agreed. At high speeds, the S is quieter than a regular car but there's still a lot of wind noise.
    And apparently, the noise is much worse in the back seats ... of my car at least. Not sure if they fixed that in more recent builds or not.
  8. Raffy.Roma
    Rome (Italy)
    Then I hope that Tesla will produce and install a noise deadening kit like it happened for the Roadster.
  9. AmpedRealtor
    AmpedRealtor Well-Known Member
    Phoenix, AZ
    Do you know how will this impact your vehicle's warranty?
  10. artsci
    artsci Sponsor
    Timonium, Maryland
    Can't imagine this will have any impact as all this involves is lining interior and wheel well panels with sound deadening material.
    In any case, below is the sound data from my first reading today on a 15 mile drive home. As noted in my first post, this route involves many different roads and road surfaces. Today I reach a maximum speed of about 90mph in a short burst and averaged about 70 mph on the Interstate, with much lower speeds on the other roads.
    The sound meter is my iPad mini with the SoundMeter+ app (accurate to plus or minus 2dBA). A very cool and highly rated app for accuracy (almost equal to a separate sound meter), and very easy to use. I placed the iPad mini on the center console and it was locked into place with a magnet. All future tests will use the same mounting and mounting point.
    As I take more readings I'll put all of this in an easy-to-compare table.
    The average dBA of 67 is equivalent to a busy library. The max of 97.7 (for only 9 milliseconds) is roughly equivalent to a car horn from 15 feet away or a train passing 100 feet away. The low of 34 is equivalent to a very quiet room fan at low speed from a distance of 1 meter.
    So not surprisingly, we're starting with very good performance, so it will very interesting to see how the sound deadening affects the highs, lows, and averages.
    Here's a great online resource that explains much of the math and theoretical basis for measuring sound pressure.
    Sound pressures readings, Artsci's Tesla Model S P85, August 14, 2014 at 6:23:47 PM EDT
    [SLM METER]
    Average Level : 67.0 dBA
    Instant Level : 47.4 dBA
    Weighting Type : dBA
    Response Speed : Fast
    Max Level : 97.7 dBA , Hold Duration : 9 msec
    Min Level : 34.1 dBA , Hold Duration : 30 msec
    Custom Calibration : None
    [NOISE DOSIMETER]
    Projected DOSE : 6.99%
    Projected TWA Level : 70.8 dBA
    DOSE : 0.39791%
    TWA Level : 50.1 dBA
    Elapsed Time : 00:27:19
    [IMPULSIVE NOISE METER]
    Transient Noise Peak : 85.4 dBA
    Transient Noise Duration : 160 msec
    Health Message : Safe level for your ears. Sound is moderate. Similar to neighborhood, moderate rainfall.
  11. jerry33
    Texas
    You haven't driven on Texas roads. Many have a large aggregate size that makes a lot of noise. It's better in the Tesla, but it's still loud. Sound deadening is one of the things on my wish-list.
  12. omarsultan
    Northern California
    I am curious to see what the wheel well treatment is and what the impact is.
  13. DrComputer
    DrComputer Active Member
    Sherman Oaks, CA
    Seems to me the biggest issue with sound on the Model S is the 21" tires and the lack of dual pane glass on the windows. Although they might be able to mute the tires sounds with deadening materials in the wheel wells, unless you are planning on replacing all of the windows with dual pane laminate glass (like I had on my Lexus LS600hL) I doubt there is much they can do for the noise that comes through the windows.
  14. AlMc
    AlMc 'When the music is on...you gotta dance' (Go Elon)
    Delaware
    Artsci: I will wait for your results , with interest. My biggest 'sound issue' is 'tire noise'. Would you mind asking how much of this noise they might think could be reduced with just treating the wheel wells once they get their first look at your car? Do you think they would do another 'local' (Delaware) car? Thanks Al
  15. artsci
    artsci Sponsor
    Timonium, Maryland
    From what I've read on the topic most of the road/tire noise comes through the lower parts of the car -- wheel wells, car floor, frunk, and trunk. That's what SUPRKAR focused on and he said it made a great difference.
  16. AlMc
    Delaware
    Ok. We just cross posted: I would be interested in this as well. Let me know if they are interested in doing another S. Approximate cost? (PM that or other details if you feel that is more appropriate.) Thanks
  17. artsci
    artsci Sponsor
    Timonium, Maryland
    I have an estimate of $1,800 - $2,000 but that's without their having seen the car. But that includes a guarantee on materials, so the only variable is labor. I'll post the final cost when the job is finished.
    The whole purpose of my doing this, assuming it makes a worthwhile difference, was to provide Mr. Sambrook with the basis for developing a kit of some kind for the Model S. When I see him next week I'll ask if he's willing to take on more Model S's at the Manchester shop. Since Bert does most of the installation work with the advice of Don, I don't see why not.
  18. SUPRKAR
    SUPRKAR Member
    New Jersey
    How did I miss this.....GO RICK
  19. artsci
    artsci Sponsor
    Timonium, Maryland
    One of the great things about the remote app is that I've been able to monitor what part of my car is being worked on by just observing when the doors, tailgate, and frunk lid are open. A few emails exchanges with Don confirm my assumptions.
    It's been in Don and Bert's hands since Monday am. For the first several days they worked on the floor and trunk. Yesterday work continued on the floor. Today they did the doors and liftgate and now they're working on the frunk and front wheel wells. The entire car is being sound deadened.
    The second day I noticed that I had left the AC on and that it was running the whole time they had the front doors open and draining the battery. So I shut it off remotely. Too much:)
    I pick up the car tomorrow anticipating driving it will be a whole new sonic experience.
  20. Ghia64
    Ghia64 Member
    Tellgren
    This is really interesting. I hope this will result in a kit, so that we europeans can have a go at it. :smile:
