Sound won't work
Discussion in 'Model S: User Interface' started by 0exhausts, Dec 28, 2016.
  1. 0exhausts
    0exhausts Member
    Danville, CA
    Hi, today I'm having an issue where no sound will work in my Model S. No music, no radio, no turn signal, no alerts, nothing. Has anyone had this happen? Is it likely just a blown fuse? I've rebooted both dash and touch screen.
  2. mblakele
    mblakele (つ ͡° ͜ʖ ͡°)つ
    SF Bay Area
    Maybe. I think the audio amp is in the cabin fusebox, which seems like a pain to get to. I think you have to remove the trim just in front of the front passenger door. I'm looking at this: https://s3.amazonaws.com/f.cl.ly/items/3b321O3Q01040I2V4420/2015%20fuses.pdf
    Have you asked Tesla to pull log data yet? They might find something.
    Another kind of reboot might be worth trying: go to Controls > Power Off. After the screens go dark, sit quietly for two full minutes. Don't touch the brake pedal or the door handle. After two full minutes, depress the brake pedal and the screens should come back. I don't have any particular reason to think this will help, but it only takes a few minutes to try.
  3. Alexander S
    Alexander S New Member
    I started having the same issue yesterday. Did you figure out the problem? I'm taking it in for service today. Wonder if it has anything to do with the new software update.
  4. Cooksomerice
    Cooksomerice Member
    Louisiana
    Same Problem.
    Everything is (audio) gone.
    I rebooted UI and dash.
    I may try the car itself next, as suggested above.
  5. Cooksomerice
    Cooksomerice Member
    Louisiana
    Any updates?
  6. Simon_elf
    Simon_elf Member
    Yorba Linda
    Same problem. I talked with service and they said it is a bug of the new firmware. You got your beta firmware updated last Friday ?
  7. 0exhausts
    0exhausts Member
    Danville, CA
    I called a service center and they said they would probably need to do a hard reset. They also mentioned that it may fix it if I reboot both screens almost simultaneously (do one, and then do the other while the first is rebooting) I tried this while driving, and it didn't seem to fix it, but then I parked car, came back to it 30 minutes later, and everything worked again.
  8. Cooksomerice
    Cooksomerice Member
    Louisiana
    I had the same result following rebootnof both console and UI
  9. Simon_elf
    Simon_elf Member
    Yorba Linda
    I just tried this twice, Non-working still. :(
  10. 0exhausts
    0exhausts Member
    Danville, CA
    Did you try turning car off? It didn't work until the next time I drove the car.
  11. Simon_elf
    Simon_elf Member
    Yorba Linda
    Yes, I tried a complete power off as well. no luck.
  12. Mxjoe
    Mxjoe Member
    Colorado
    I'm having the same problem. I spoke with my SC, still waiting for an answer.
  13. Mxjoe
    Mxjoe Member
    Colorado
    Spoke with my SC. They said I have bring in the vehicle to fix the problem. I have to wait 13 days to get an appointment, Jan 20th(Denver). Almost 2 weeks with no music, Bluetooth or any sound. Not happy at all.
  14. Simon_elf
    Simon_elf Member
    Yorba Linda
    My SC appointment is on 1/10. I will update if I got any useful information. What bothering me is the No sound Bluetooth, you can't take phone call while driving.
  15. Mxjoe
    Mxjoe Member
    Colorado
    Simon let me know how it goes and what they say. Just curious, is any sound working-signal lights, seat warning, other warning chimes?
  16. Simon_elf
    Simon_elf Member
    Yorba Linda
    Nope, nothing, like your vehicle are completely muted.
  17. FishHead
    FishHead Member
    Hong Kong
    Happened to me yesterday. Everything muted. Tried rebooting screen and dash. No luck. Tried my phone, nothing. Reached a supercharging station and put the car to charge. Disconnected my phone, then reconnected. Tried playing music, nothing. Then I received a call on my phone and suddenly I hear the phone on the speakers. After that everything worked perfectly again. Very strange!
  18. Mxjoe
    Mxjoe Member
    Colorado
    spoke with the service center again today, good news they can get me in this Thursday to check it out. The rep on the phone mentioned if I did the xmas easter egg. Coincidentally, the problems happen a little bit after I ran it twice. Not sure if this caused the problem.
  19. MorrisonHiker
    MorrisonHiker S 90D 2018.26
    Colorado
    Did you happen to call the Denver SC around 10 on Saturday morning? While I was waiting to get a tire replaced, someone called in with this same issue. I couldn't hear the person calling in but could tell from what the receptionist was saying that the caller was having this problem and the receptionist was asking if the caller had tried rebooting.
  20. apacheguy
    apacheguy S Sig #255
    So Cal
    Please post the cause/fix when you hear back.
