Southern California Edison & Electrician
Discussion in 'California' started by Len, Jan 20, 2014.
Tags:
  1. Len
    Len Member
    Laguna Niguel
    Hello,
    I just ordered and finalized my MS order on Fri (I should have my car in March). I was wondering if anyone in Orange County has installed a second meter, if so can you please answer the below questions:
    1. Has it been worth it.
    2. How much was the installation from your electrician to split the line, install the second panel and have it ready for SCE (SCE installs the meter for free)?
    3. Can you recommend an electrician?
    The Tesla store recommended an electrician, I had him come out and give me a quote for a 220 outlet, however, he has not done a second meter installation and he was not too sure how to do it.
    Thank you,
    Len
  2. viet658
    viet658 Member
    Pomona, CA
  3. Len
    Len Member
    Laguna Niguel
    Thank you!
  4. BIGDJE
    BIGDJE Member
    Newport Coast
    you don't need a 2nd meter
    I called SCE and they put me on the electric car plan. took about a month to set up. it is .10/kwh 12am to 6am in summer and ..09/kwh for winter rates that's it nothing else needed
    I have 100amp breaker installed with HPC and works great
    also that goes for any draw on power at that time washer dryer ac anything so you save your whole house vs getting 2nd meter and only save on car charge
    - - - Updated - - -
    Home & Electric Vehicle Plan (TOU-D-TEV) [TH="class: thleft, colspan: 2"]Summer[/TH][TH="class: thright, colspan: 2"]Winter[/TH][TR="class: odd"][/TR][TR="class: odd"][/TR]
    Tier 1 RateTier 2 RateTier 1 RateTier 2 Rate
    On-Peak
    10 AM - 6 PM weekdays
    28 ¢ / kWh47 ¢ / kWh16 ¢ / kWh35 ¢ / kWh
    Off-Peak
    All other times
    12 ¢ / kWh31 ¢ / kWh11 ¢ / kWh30 ¢ / kWh
    Super Off-Peak
    Midnight to 6 AM every day
    9 ¢ / kWh9 ¢ / kWh10 ¢ / kWh10 ¢ / kWh
    also you can check direct here https://www.sce.com/wps/portal/home/residential/rates/residential-rates/!ut/p/b1/rVXLcpswFP2WLrzUcPVCaAmtQ4DEODbjxGw8QoiUNCZOzGTafH1lxzMpdutHXFa60tXRuec-cHLnzskb9Vrfq7Z-atTjys7dGfZC_zIaQ-QllEEUsH6WfiVhMgTn1smdXDftov3uTJfazPRT05qmnZmmB5t1D17Msi7tqlaP1lCtWXb20HprhbRQ96a0B_fN2tJ16UxxSTwKiqBKG0AMFwIVheIIF4C5piBMwSzRqSUK__h86MYRjgSBKJ70r9IAE_DI5v4eh64OWdi3OiQgJ0NCmRDb93cduu8PudUxFhkIMcbexc79XYcDeRib5j0XB1RYO8gQ-pdxap_JbihE9AYGY9-nAO7GYY8OU0tUfDiAiLll4iciwBMa-dgZf2TOFVVpjJFIcUMRKzRD0iMaESmkxkYqVbJtwK0XU3Y2YMZWDImgYRBRSPjJgPERxVM_PD_nvm2FVcn_bJ27Y3rBGVw-zc024a3auXD_JOwRDCUmClWeKBFzCw8pSgQSTJY2EiCVpAcAB_RcwHS4UiDw4xFIGXyT4mTA-Ih--pSkPTCPRrcvtUZavSx3iqHTVyl0qksqURIbGdIcDGK6MkgRpRCXylXYxWUBYj-gN6HnAqY8BCtFP0yugwzkiJ8MGB8xaz6p7fuc3i6v7jDinRFw1PDeDzgU_xmQs5MB40Pz90xN__Y7XMzn3kOVJMkV-zHygPLF61tWzW9ROJ8NBkgV3i-62lhbebE5ns-ul_6X32bnIZk!/dl4/d5/L2dBISEvZ0FBIS9nQSEh/#/accordionGrp1-2/accordionGrp1-1
    - - - Updated - - -
    you can get all the info here https://www.sce.com/wps/portal/home/residential/rates/residential-rates/!ut/p/b1/rVXLcpswFP2WLrzUcPVCaAmtQ4DEODbjxGw8QoiUNCZOzGTafH1lxzMpdutHXFa60tXRuec-cHLnzskb9Vrfq7Z-atTjys7dGfZC_zIaQ-QllEEUsH6WfiVhMgTn1smdXDftov3uTJfazPRT05qmnZmmB5t1D17Msi7tqlaP1lCtWXb20HprhbRQ96a0B_fN2tJ16UxxSTwKiqBKG0AMFwIVheIIF4C5piBMwSzRqSUK__h86MYRjgSBKJ70r9IAE_DI5v4eh64OWdi3OiQgJ0NCmRDb93cduu8PudUxFhkIMcbexc79XYcDeRib5j0XB1RYO8gQ-pdxap_JbihE9AYGY9-nAO7GYY8OU0tUfDiAiLll4iciwBMa-dgZf2TOFVVpjJFIcUMRKzRD0iMaESmkxkYqVbJtwK0XU3Y2YMZWDImgYRBRSPjJgPERxVM_PD_nvm2FVcn_bJ27Y3rBGVw-zc024a3auXD_JOwRDCUmClWeKBFzCw8pSgQSTJY2EiCVpAcAB_RcwHS4UiDw4xFIGXyT4mTA-Ih--pSkPTCPRrcvtUZavSx3iqHTVyl0qksqURIbGdIcDGK6MkgRpRCXylXYxWUBYj-gN6HnAqY8BCtFP0yugwzkiJ8MGB8xaz6p7fuc3i6v7jDinRFw1PDeDzgU_xmQs5MB40Pz90xN__Y7XMzn3kOVJMkV-zHygPLF61tWzW9ROJ8NBkgV3i-62lhbebE5ns-ul_6X32bnIZk!/dl4/d5/L2dBISEvZ0FBIS9nQSEh/#/accordionGrp1-2/accordionGrp1-1
  5. simplesolar
    simplesolar Member
    SoCal
    problem with this is that if you use electricity during peak hour in the summer time it is 47cents which can add up to a lot if someone is home during the day.
  6. Len
    Len Member
    Laguna Niguel
    Thank you, I'm going to try the electric car plan.
    Len
  7. Alexander
    Alexander P# 8,878
    Valencia, CA
    I choose to get the second meter over the Home & Electric Car Plan. I drive a lot and need to charge during the day. It also helps me track my expenses for tax purposes.
    Without a doubt, it's cheaper to go with the "Home & Electric Car Plan" IF you only charge at night and don't use a lot of electricity during On-Peak and Off-Peak hours...
    Between 10AM and 6PM (On-Peak) your rate starts at $0.28/kWh for Tier 1 and goes up to $0.47/kWh for Tier 2. MUCH more expensive then the standard plan.
    During Off-Peak hours your rate is $0.12/kWh for Tier 1 (which is actually 1 penny cheaper then the standard rate), but your Tier 2 rate is $0.31/kWh. So your Tier 2 rate is almost double that of the standard Tier 2 rate.
    So again, as long as you only charge at night and don't use a lot of electricity during On-Peak and Off-Peak hours, its by far the cheaper way to go. But if your like me and use a lot of energy during On-Peak and Off-Peak hours, its best to get the separate meter.
    My separate meter is going to cost $1,500.00. I think I could of gotten someone to do it for less, but he was the only one who could do it on short notice and I need it done ASAP. My electric bill is approaching $686 for the month, so I need my meter now. With the meter my bill would of been $179.89. (again I do a lot of driving)
  8. Len
    Len Member
    Laguna Niguel
    Thank you, that is a significant savings. I don't use a lot of electricity during On-Peak hours and I am planning on charging at night. I'm going to go with the Home Electric Car Plan and monitor my electric bill for a couple of months and then re-evaluate my decision.
    Semper Fi
    Len
  9. miimura
    miimura Active Member
    Los Altos, CA
    If your home is at all conducive to solar installation it is much better to put money into solar than a separate meter to lower your bill. SCE Home & Electric Car plan is WAY more beneficial for solar than the EV plans from PG&E.
  10. WarrenT
    WarrenT Member
    Orange County, CA
    Len I live in Aliso Viejo right next to you. I also don't use much electricity during on-peak & only charge my car at midnight during the super off-peak time. I went with the Home Electric Car Plan and it's definitely saving me money. I also looked into solar and had quotes from 3 companies. After doing a lot of number crunching, I found that for me solar was not worth it. I'm a fairly conservative electricity user (25kwh a day avg, with about 14kwh of that being from my Tesla). You need to be a decently high electricity user to gain significant benefits from going solar.
  11. miimura
    Los Altos, CA
    Yes, your household usage is very low. Most people in CA with 3-4 person household have electric bills more than $100/mo. Those people can easily benefit from solar. You, not so much.
  12. lasalle123
    lasalle123 New Member
    oak park
    Alexander, Who was your electrician that charged you $1,500 for a second meter? I'm looking for a referral. Thanks
