Yggdrasill
May be that the thrusters could be used to also improve downforce, but I don't think the math works out. The 45 kg air system I did some math on earlier could do 7350N for 3 seconds. If the 2020 Roadster weighs 2000 kg loaded, the 7350N could be used to increase downforce by 37.5% for 3 seconds. And at that point, forget about replenishing the air supply in the near term. This was 45 kg at 700 bar - it might take hours to compress that much air.@ Yggdrasill don't focus on propulsion, focus on downforce and center of pressure.
The motor has more than enough power, the issue is grip for acceleration, braking distance and cornering. Grip is the limitation, why they can't accelerate/brake faster.
The tires have a friction coefficient and you can add downforce to improve on that.
A normal car decelerates at 1g, a Formula 1 car does it north of 5g and the bulk of that is due to the downforce.
Sucking air from under the car does quite a lot, a diffser does that and is plenty useful but add fans to suck air and it get crazy.
Aero features can give you downforce while adding minimal drag, Active aero is even cooler as it gives you flexibility and you can even add drag when needed. This is, no idea how to call it, let's say super-active aero.
Downforce scales with the square of speed just like drag so it's very relevant at high speeds but very little at low speeds.
And this is where the jets can help, at low speed more than at high speed. They can help a little at high speed too but at high speed you can create downforce with the air intake and other aero features. At low speeds they are more useful as downforce doesn't help you much at all so it's a neat trick. They likely use them mostly in bursts or they would need to either be able to compress air in real time or have large air "tanks".
For example, a normal car decelerating at 1g needs almost 700m for a full stop from 400km/h. A Bugatti Veyron can decelerate at 1.3g from that speed and stops in under 500m. An F1 car likely does it in towards 100m.
So to recap, the car doesn't need extra propulsion, it has a huge amount as it is, the hard part is how to apply it to the road.
Using propane to provide propulsion seems like the route to go.
