skitown
Except, of course, Bosch's version probably uses pure diesel NOx.Like this from Bosch but made by SpaceX instead.
Space X has been working on new rocket engines that use methane instead of the standard kerosene-based rocket fuel, so I suppose that technology could find it's way to cars, but it would really go against their zero emission goals. I'm more inclined to think they would use water heated by electricity.... assuming this is not all in jest. It would essentially be a vape car.
Correct, pure electric.
Note, gas contained would be ultra high pressure air in a SpaceX rocket COPV bottle. The air exiting the thrusters would immediately be replenished whenever vehicle pack power draw allowed operation of the air pump, which is most of the time.
Not recommended for urban environments
Exactly. Total energy stored even in ultra compressed air is low vs battery, but power output is insane. The composite overwrapped pressure vessel (COPV) is most advanced ever made. It’s what SpaceX is qualifying for NASA crewed missions. Extremely robust — literally bulletproof.
Man that is wild! Okay, I stand corrected. There really is going to be such an option on the new Roadster.
Writing the software to control such a system in a road car is going to be challenging.
I highly doubt it will be included. Depending on the specs, it could be worth doubleThe question that needs to be answered is the price for the SpaceX option, and whether or not it is included in the Founders model.
With 4.8 kWh of energy stored in the tank, and assuming a 70% efficiency for the compressor, it would take 1 hour to refill the tank with a 7 kW compressor. With a 50 kW compressor, it would take 8 minutes. With a 100 kW compressor, 4 minutes. Or put differently, if you have a 2000N burst for 1 second, it will take 35 seconds to refill the tank, with a 50 kW compressor. 18 seconds with a 100 kW compressor....
Well, it’s a tweet from Elon. So my answer would be...sort of. I added Elon’s tweets about the “SpaceX option package” to the pinned post in this forum.But is it a verified fact?
If the Roadster has 47.57 kg of air and it fires off ten 3500N thrusters, the tanks will be empty in about 0.8 seconds, though. Assuming an Isp of 60, that is.@ Yggdrasill
Was thinking that Pa is newton per m3 so why not look at area. at 350 bar a 1cm2 (0.0001m2) nozzle would result in 3500N so that would be a simple max force. If they got 10 of those, that''s 35000N so the equivalent of 3571.4kg and that's before any increase in downforce at air intake and impact of the jets on aero.
There are some other factors to consider and some efficiency losses ofc. How fast that force drops depends on tank size.
If they can adjust the flow at the nozzle and they do want to do that, they can apply less force for just enough. Ofc the 1cm2 nozzle area is arbitrary, it could be a few times larger for more flexibility. Likely the limitation is structural integrity and no idea how they deal with that.
I'm not so sure it's just a matter of attaching a big motor to a fan. I think you need several fans, depending on how high in pressure you're going. I know you at least need several fans to get a high vacuum. Each fan has a range of pressure where it does it's job well, and outside that area it's pretty useless.I can see this... A model 3 motor attached to a high pressure pump. That would give you an (up to) 190 kW compressor, no? Also Elon mentioned a while ago that their COPV tanks run at 380 bar (which then survived re-entry!). Maybe more like 70Kg of compressed air, give-or-take at that pressure?
I wonder how Tesla is going to deal with the noise issue; 1000N thrusters are not going to be quiet...
you may have forgotten ambient air viscosity in your calculations. It occurs we don't need to depend on specific impulse only for a thruster designed for mostly sea level operation. With the right geometry thrusters, you should be able to get the same order of magnitude energy back as you inserted in COPV .If the Roadster has 47.57 kg of air and it fires off ten 3500N thrusters, the tanks will be empty in about 0.8 seconds, though. Assuming an Isp of 60, that is.
I think they will more likely go for smaller thrusters, and simply fire them for a longer duration, than go for a bigger thruster. I expect the thrusters will be positioned roughly like this:
So if you want acceleration, you fire 6-9, if you want deceleration, you fire 2 and 3. If you're making a turn to the left and get understeer, you fire 4 and/or 10, and if you get oversteer you fire 1 and/or 5. To drift while making a turn to the left, you could fire 10 and/or 1. You basically have lots of options, but you never fire all the thrusters at the same time.
(Oh, btw, I'm not Franz, if you couldn't tell. )
