serverguy247
you may have forgotten ambient air viscosity in your calculations. It occurs we don't need to depend on specific impulse only for a thruster designed for mostly sea level operation. With the right geometry thrusters, you should be able to get the same order of magnitude energy back as you inserted in COPV .
I'm going out on a limb here; but perhaps you could add little compressors and bypass fans to the thrusters to increase their "grip" of the air, the way a jet has bypass fans to multiply its thrust. Although I don't know if there would be too much inertia to spool up fast enough.
Or skip the fan and just have an outer cowl... A bit like a ramjet / dyson air multiplier type affair.
If we had around 150Kg of air (as A X 3 found with the off-the-shelf COPV from SpaceX) with an ISP of 70 in a vac (possibly more?). That is a significant amount. 1000n thrust over 10 seconds, maybe?
