Question about the time gap between the end of second stage burn two and when they release the satellite. After the second burn is over, why hold onto the satellite for so long if the second stage is done at that point? Why not release it shortly after the burn is over once everything checks out? If there aren’t any additional burns planned what’s the point of holding onto it for so long after?
I dont think it is time critical when the separation occurs since it is after the last burn. It won’t affect the payload orbit. I believe what they are doing in that time is double and triple checking the orbit to make sure it is correct. They may need to check position at different times to get a truly accurate reading of the orbit. If something isn’t right, the second stage can be called on again to tweak the orbit.
