jkn
504
321
EU
The fairings are reflecting the sun which makes them bright. The fairings seem like they have thrusters but in actuality they are just caught in the exhaust of the second stage rocket and are reflecting the gasses.
At least one fairing had thrusters.
SwTslaGrl
594
2,369
Sweden
"The Falcon 9’s aerodynamic nose cone split open and fell away in two pieces shortly after the mission’s three-minute point, and control thrusters on the fairing were also visible pulsing to position the pieces for re-entry. SpaceX is experimenting with recovering the Falcon 9’s fairing off shore for reuse, as the company does with its Falcon 9 first stages."
Falcon 9 launch lights up Southern California sky – Spaceflight Now
"SpaceX was expected to try and retrieve part of the Falcon 9’s payload shroud downrange from Vandenberg after Friday’s launch. A fast boat linked to experimental fairing recovery attempts, named Mr. Steven, was relocated from Florida to California in recent weeks, and it sailed south from the Port of Los Angeles on a heading toward the Falcon 9’s projected flight path."
SpaceX launch dazzles, delivering 10 more satellites for Iridium – Spaceflight Now
ecarfan
19,186
13,841
San Mateo, CA
(The sunlight) could make even black sides of fairing halves to look bright
Well, maybe. But I’m not convinced.
I think fairing parts automatically stabilize soon after separation.
And how do you think SpaceX accomplishes that feat? Cold gas thrusters? I don’t know how else it could be done given that fairing separation occurs above the atmosphere.
jkn
504
321
EU
Cold gas thrusters are only possibility. Since fairings are relatively light, small thrusters will be enough and re-entry heat load/area is small. Fairings must be aerodynamically stable. Thrusters are needed to set initial attitude.
ggr
Expert in Dunning-Kruger Effect!
Mar 24, 2011
6,972
27,477
San Diego, CA
It could be done with gyros, but SpaceX knows a lot about thrusters, so I agree that is probably how it is done.
Reactions: GSP
Doug_G
Lead Moderator
Apr 2, 2010
17,877
3,337
Ottawa, Canada
Gyros are complex, and have limited ability to torque (due to their limited weight) and limits to the control authority (i.e. when the saturate at maximum speed). That's why satellites have both gyros and thrusters. The gyros are used for continuous stabilization, and the thrusters are used to unload the gyros.
Nitrogen thrusters would seem to be the appropriate technology for this purpose.
bxr140
2,628
3,321
Bay Area
It’s a bit pedantic, but in context of space stuff, gyros are rate sensing devices and momentum or reaction wheels are the attitude control devices.
Also, rockets have gyros.
Fairings typically go through an oscillation stage immediately after separation and then a relatively low rate tumble ‘away’ from the rocket. That’s due largely to the fact that there’s intentional stresses in the encapsulated configuration (plus springs) that push the halves away from the payload/rocket—the det cord and pyro devices that actually break the halves apart can’t safely separate them on their own. The post separation motion is a very understood and modelable phenomenon, and so it’s probably pretty easy to derive the minimum amount of thrust/vectors required for a system like cold gas to stabilize the fairing halves. They’re so big and so light that it seems quite feasible for thrusters mounted on the top or bottom to right the ship pretty easily.
Lastly, I don’t think one can draw the conclusion that the fairings aren’t tumbling based on the home videos that show an apparent constant brightness. Even black MLI can sometimes be pretty shiney.
Reactions: e-FTW and Mike1080i
SwTslaGrl
594
2,369
Sweden
Just some screen shots from one of the videos,
mongo
12,866
37,855
Michigan
For SpaceX, they do not use explosives for any of the stage/ fairing separations.
pneumatic system allows for acceptance and functional testing of the actual flight hardware, which is not possible with a traditional explosives-based separation system.
ecarfan
19,186
13,841
San Mateo, CA
Good point, that likely explains what the videos appear to show. Thank you.
Reactions: Grendal
ggr
Mar 24, 2011
6,972
27,477
San Diego, CA
Yes, thanks for correcting my terminology.
I think from my tour that I remember the guide saying that SpaceX doesn't use pyro devices at all, for anything. I'm pretty sure the fairings are separated with springs.
bxr140
2,628
3,321
Bay Area
How would springs be activated? A cam being rotated, perhaps?
No. Really broad brushing this one, typically release mechanisms come in a few flavors—pulling/pushing pins, cut rods, or detonation cord. The devices that initiate those mechanisms are typically pyro charges, heaters, servos, and pneumatics.
For an example of a non-pyro rod cutter, check out Frangibolt - TiNi Aerospace, Inc.. It’s basically a cylinder that heats up, expands, and stretches a rod that runs through the middle of the cylinder until the rod breaks. They have a bunch of other products for other release gizmos to if you want to get an idea what these things actually look like.
Back to springs, they’re typically basic coils and are preloaded during installation so when the mechanism releases The Newtons happen. In the case of fairings they’re typically also preloaded with some internal ‘spring force’—I haven’t actually seen a falcon fairing being mated though so I don’t really know the configuration. :(
