SpaceX F9 - CSG-2 - SLC-40
Grendal
SpaceX Moderator
Moderator
Jan 31, 2012
7,844
12,087
Santa Fe, New Mexico
Launch Date: January 31
Launch Window: 6:11pm EST (3:11pm PST, 23:11 UTC)
Launch site: SLC-40, Cape Canaveral Space Force Station, Florida
Booster Recovery: RTLS
Booster Type: B1052-3
Fairings: Likely Reused
Mass: 2205 kg (4860 lb)
Orbit: SSO
Second COSMO-SkyMed 2nd Generation satellite. Originally scheduled to launch in 2021 on an ArianSpace Vega-C rocket, resulting delays caused the pandemic and two Vega launch failures led to ASI purchasing a Falcon 9 launch contract in September 2021 for the 2.2 ton satellite.
Stats:
  • This will be SpaceX's 4th orbital launch of the year
  • If successful this would be SpaceX's 112th successful orbital launch within the Falcon program in a row since the last failure.
  • This will be Falcon 9's 137th orbital flight
  • This will be the 6th flight of this booster.
  • This will be SpaceX's 78th launch from SLC-40.
  • This will be the 18th landing attempt at LZ-1.
The booster for this mission, B1052-3, previously supported the Arabsat 6A and STP-2 missions as a Falcon Heavy side booster. It has been converted to a standard F9 booster. This is the first time this has ever happened.
Super pedantic, but mass in the text is correct (2.2T).
Also interesting that is going to be a dogleg out of Florida. Given the ASDS landing they're definitely putting more sats on that rocket. (SOCOM was RTLS so its not like there's some technical reason the dogleg SSO can't be RTLS). It would also be odd for the cosmo mission to just fork out another ~20M or whatever for the falcon over the Vega.
Weather is good.
Reactions: 808?
