So true.The zoom on that picture is indicative of the more important subject in the frame.
During MECO the interstage detaches from 2nd stage and stays attached with the first stage and lands, whereas in this picture it is shown attached to 2nd stage and detached from 1st stage.
Wondering if that is how it is assembled.
You are right.. thanks.Look at it again. The interstage is attached to the booster stage. The second stage bell just slides all the way in to the interstage normally. Right now, they are separated.
The second stage is on the left of the picture and the black is the interstage attached to the booster stage on the right.
When the stages separate, the 1st stage has to slide away without hitting the 2nd stage nozzle (bell) and damaging it. Thats got to be a bit tricky, because the separation happens at incredible speed and through pyrotechnics. So I guess there will be a lot of vibration and shaking. Any damage to the nozzle will impact the 2nd stage performance
Interesting.No pyrotechnics on SpaceX. Helium powered pusher shoves the 2nd stage out via ram in the engine throat. The center part of the tripod structure in the interstage.
Three clamps on the edge, I think. There is a great video with footage from the first stage getting towed into Canaveral that goes through all the bits...Interesting.
Aren't they bolted together on the rim? how do you un-bolt them during MECO? I thought it is a two step process happening in very rapid succession - you first remove whatever holds them together through pyrotechnics and then push/shove them away through other means
Bridenstine working on getting favorite Oval Office chair to keep Pence around for the launch.Scrubbed for today as well. They're still having family issues.
I’m picturing a group of siblings in SpaceX mission control arguing over who gets to sit next to Gywnne at launch...Scrubbed for today as well. They're still having family issues.
The phrase “out of family reading” is an odd one to my ears, though I think I understand it in this context: essentially “too far out of the acceptable range”, I assume. Is the phrase commonly used terminology in aerospace or rockets?
Now targeting December 22 launch of GPS III SV01. Weather is 80% favorable for the launch window which opens at 8:55 a.m. EST, 13:55 UTC.
