SpaceX F9 - JCSAT 18/Kacific 1 - SLC-40
e-FTW
New electron smell
Aug 23, 2015
3,355
3,255
San Francisco, CA
Launch Date: Dec 16th-17th
Launch Window: 0010-0138 GMT on Dec 17th (7:10-8:38 p.m. EST on Dec 16th)
Launch site: SLC-40 Cape Canaveral
Booster Recovery: ASDS
Booster: B1056.3
Fairings: The Go's are heading out for recovery
Mass: 6956 kg (15,355 lbs)
Orbit: GTO
A SpaceX Falcon 9 rocket will launch the JCSAT 18/Kacific 1 communications satellite jointly owned by SKY Perfect JSAT Corp. of Japan and Kacific Broadband Satellites of Singapore. Built by Boeing, the JCSAT 18/Kacific 1 communications satellite will provide mobile and broadband services across the Asia-Pacific region.
At 6800 kg, this one is extremely heavy.
From NASASpaceflight article:
The mission set for launch Monday will mark SpaceX’s 13th flight of the year, and the second in 11 days from the same launch pad at Cape Canaveral Air Force Station. If the Falcon 9 takes off Monday night, it would mark the fastest turnaround between SpaceX missions from the same launch pad.
JCSat 18 / Kacific 1
Reactions: Grendal
e-FTW
New electron smell
Aug 23, 2015
3,355
3,255
San Francisco, CA
Reactions: Grendal
Grendal
SpaceX Moderator
Moderator
Jan 31, 2012
6,793
9,530
Santa Fe, New Mexico
Reactions: e-FTW
e-FTW
New electron smell
Aug 23, 2015
3,355
3,255
San Francisco, CA
No details I can find on where the Falcon will place the satellite or whether there will be a recovery. It ends up in GEO though.
This satellite is heavier than Arabsat 6A - which used a FH to get it where it needed to go.
That said, Telstar 18V was heavier and the booster was recovered.
Kacific1 satellite arrives at SpaceX launch site in Cape Canaveral, Florida - Kacific
Right on about Telstar 18V, 7060kg to GTO, with ASDS landing.
I was going by Teslarati speculation:
“Although Falcon 9 has been significantly upgraded since 2017, launching a 6.8-ton satellite to a full geostationary transfer orbit (GTO) is still out of the question, meaning that Kacific-1 will either require expendable Falcon 9 performance or be launched to a subsynchronous transfer orbit. The latter is significantly more likely, as the opportunity cost of expending a Falcon 9 Block 5 booster is large enough to encourage SpaceX to avoid it if at all possible.”
Reactions: Grendal
Grendal
SpaceX Moderator
Moderator
Jan 31, 2012
6,793
9,530
Early weather report for the launch. 90% positive. We had 90% for CRS-19 and was still delayed for a day. So even 90% is not a sure thing... :)
Reactions: e-FTW
Nikxice
1,203
2,079
Hudson, NH
SpaceXNow currently shows this launch is scheduled for 4:10PM Pacific Time on Dec 16, tomorrow. Is that correct?
That's affirmative. It appears Grendal has recently edited the correct date/time at the top of this page. Backup window is on Tuesday, exactly 24 hours later. Still looking at 90% Monday. The primary concern is launching with some cumulus clouds in the area, upper level winds 55kts. Tuesday down to 50% with with upper level winds at 75kts, generating more concern for possible wind shear. OCISLY is being towed into position by tugboat Hawk and both Go ships are a go for individual attempts to catch a fairing.
Reactions: e-FTW and Grendal
