We are looking for another podcast participant who can act as a lead co-host to join the TMC Podcast. If you are interested in participating please see this thread.
I'd speculate that they're actively deorbiting two (or maybe four?) and then to varying degrees passively deorbiting the rest, with likely a couple different attitudes to quantify drag.
No, all of them are going down. Here is what graph should look like, green lines are tension rods (time scale is longer, but idea is same):
And here is today’s graph. Sats in the red circle look dead and are in random attitudes, decay depends where solar panels are pointing → different drag, greens are deorbiting. (I added the Reds and Greens, and are not in the original graph Index of /space/con/star)
So a possible explanation is that all of the new argon Hall Effect thrusters have failed. If true, this must be a big disappointment for Starlink. Whatever the cause, this is a costly failure.
Those satellites were at orbital speed. They wouldn't de-orbit unless SpaceX wanted it to happen. It is possibly because there was an issue with the Hall Effect thrusters but it could be something to do with some other aspect of the satellite.
Satellites are deployed at low orbit where atmospheric drag is quite high, example tie rods come down less than a month. Also actual astronomer (Who's site these graphs are from) says that it looks like natural decay:
So if they have stabilized at that orbit, and the rest of the batch are heading that direction... is it possible that an orbit at 365km is the intended destination? Wikipeida says:
Overall, SpaceX had requested approval for as many as 29,988 Gen2 satellites ... ~20,000 in 340–360 km shells
Perhaps the first two were a test of the new thruster capability? Would there be any reason to launch higher and then bring them down? Some sort of contingency plan if the thrusters didn't perform?
