SpaceX F9 - Telstar 18V - SLC-40
Discussion in 'SpaceX' started by Grendal, Jul 22, 2018.
Tags:
  1. Grendal
    Grendal SpaceX Moderator
    Santa Fe, New Mexico
    #1 Grendal, Jul 22, 2018
    Launch Date: September 9/10
    Launch Window: 0328-0728 GMT on 9th (11:28 p.m.-3:28 a.m. EDT on 9th/10th)
    Launch site: SLC-40
    Booster Recovery: ASDS on OCISLY
    Booster Type: B1049 - New Block 5
    Orbit: GTO
    A SpaceX Falcon 9 rocket will launch the Telstar 18 VANTAGE communications satellite for Telesat. The Telstar 18 VANTAGE satellite will provide high-throughput Ku-band and Ka-band communications services, supporting broadband applications over India, China, Mongolia, Southeast Asia, and the Pacific Ocean region. APT Satellite of Hong Kong has an agreement to use capacity on Telstar 18V, which is also known as Apstar 5C. The satellite was built SSL. The weight/mass has not been announced yet. It is likely to be on the heavy side since Telstar 19V was 7080 kg. Anywhere from 4500 kg to 6000+ kg.
    Edit: Confirmed the satellite is 7060 kg. That makes it the second heaviest commercial satellite ever launched. SpaceX is truly on a roll.
    Telstar 18V (Telstar 18 Vantage) / APStar 5C
    Satbeams - World Of Satellites at your fingertips
    If the schedule holds and no issues happen, this will be:
    The 16th SpaceX launch of the year
    7th new booster of the year
    4th new Block 5 launched
    23rd booster recovery in a row
  2. Electroman
    Electroman Well-Known Member
    TX
    Except I thought the first one would be dismantled for investigation and not reused..?
  3. Grendal
    The first one will be dismantled and put back together for reuse. It's definitely planned for reuse. They may reuse a later booster first if it takes a while to put it back together.
  4. ccutrer
    ccutrer Active Member
    Eagle Mountain, UT
    Humpty Dumpty.... all the king's men... something something...
  5. Grendal
    It looks like the dismantling and investigation didn't take nearly as long as some people thought. The first Block 5 will be reused for the Merah Putih launch; after about 2 months of examination.
    The first post for this launch has been modified to reflect the Merah Putih reuse.
  6. Grendal
    Bumped out again. First post reflect change.
  7. MacGreiner
    MD
    Bummed. Down here until Friday was hoping to stop by on Max Brewer to watch on the way home.
  8. Grendal
    Big slip into September. Not sure as to why just yet.
    Edit: Rumors say it had to do with SpaceX and not the satellite company. Don't know what the issue was though.
  9. anticitizen13.7
    anticitizen13.7 Not posting at TMC after 9/17/2018
    United States
    • Informative x 2
  10. Grendal
    Weather for the launch is not good: 60% favorable. The same number for the next day if the launch is pushed.
  11. Grendal
    • Informative x 3
  12. anticitizen13.7
    United States
  13. Grendal
    Webcast! As Anticitizen mentioned the weather is not good.
  14. Grendal
    Everyday Astronaut's livestream:
  15. MyJoule
    MyJoule Member
    Tucson, Az
    Just saw it's pushed back to 12:00AM EST
  16. Grendal
    32 minute delay, so far.
  17. SMAlset
    SMAlset Well-Known Member
    SF Bay Area
    Ready and waiting here. I suddenly remembered it was to launch tonight and at least didn't miss it. Live is always more exciting.
  18. Piney999
    Piney999 Member
    East of Pikes Peak, Earth
    Is the delay for weather at the launch site?
  19. MyJoule
    MyJoule Member
    Tucson, Az
    #19 MyJoule, Sep 9, 2018
    Now showing 12:45AM - Twitter feed says weather caused and payload and Falcon 9 in good shape
  20. Grendal
    Now 12:45. SpaceX is looking for a good weather window to make this happen and adjusting on the fly.
