Wiki SpaceX Manifest and Launch Cadence
miimura
5,998
5,577
Los Altos, CA
  • | This is a WikiPost. Members with appropriate permissions may edit.
I've made this a wiki thread; this first post can be edited by regular members.
This gives you a list of past and future launches with pertinent details for each in an easy to read format:
List of Falcon 9 and Falcon Heavy launches - Wikipedia
Here are two websites that track upcoming launches including their time frame:
Launch Schedule – Spaceflight Now
Launch Calendar - SpaceFlight Insider
Here is a wiki of SpaceX booster cores. It tells you everything known about a completed booster:
cores - spacex
Original text:
What is going on with the SpaceX manifest? I thought I recently counted 4 launches scheduled for April 2017 (maybe counting SES-10 in that count..). Now the NROL mission is pushed out to the end of the month and the Inmarsat mission was pushed out 2+ weeks after that. CRS-11 and BulgariaSat are also scheduled for May, but April looks like a bit of a bust.
Grendal
SpaceX Moderator
Jan 31, 2012
5,696
6,863
Santa Fe, New Mexico
I understand. Here is the rough launch list from wiki for those that aren't aware of the very full manifest that SpaceX has:
To address your point. From what I'm reading that because this is a classified NRO launch that it has priority so another launch can't really pop in and get sent up in the NRO slot. This is exactly where having LC-40 up and running would make a huge difference because SpaceX could move over to that pad and get a launch in. I believe the Inmarsat booster is just arriving at the Cape right now. With the classified NRO payload on site you can't mix in the Inmarsat prep without causing a huge fuss. If this were a regular payload then SpaceX may have been able to do a swap like CRS-10 and EchoStar. No question that SpaceX has an ambitious launch schedule and this delay is a huge annoyance to achieving their launch goals.
Reactions: NikeWings
ecarfan
19,186
13,841
San Mateo, CA
Yep. And I think it's also clear that the NRO launch is very important to SpaceX and they don't want to kick up a fuss if it negatively impacts their schedule, because this launch will show the US government that SpaceX can put government satellites in orbit for a lot less money than what it has cost before, and serve to (I hope) shut up the Congressional critics and show up the "old space" launch providers who have had it much too easy for far too long.
Reactions: Grendal
adiggs
4,181
11,406
Portland, OR
I like the ending quote - that sounds like somebody that can see into the future and has an imagination. "I feel pretty comfortable that we'll get comfortable" (regarding using rockets that have flown before). He's not saying he understands all the issues, or that the Air Force is ready to go flight proven immediately, but he can see a path to figuring all that out.
Bobfitz1
1,164
3,568
Ludlow, Vt
What is SpaceX currently saying about how much longer before LC-40 is useable? Seems like it has been down quite a while (given how fast they normally get things done).
Thanks!
Grendal
SpaceX Moderator
Jan 31, 2012
5,696
6,863
Thanks!
SpaceX is saying that they intend to have SLC-40 up and running before they attempt the Falcon Heavy launch. So that means that they expect LC-40 to be repaired sometime in the next two or three months. Falcon Heavy is penciled in for late summer. After the September anomaly SpaceX had to make a decision on what to focus on and chose to make LC-39A the priority since they only have one major build and repair team. LC-39A had already had a lot of work done to it so it made the most sense. SLC-40 just had some basic clean up done while all the focus was placed on LC-39A. Now that work is done the focus is now mostly back on SLC-40. The reason for having SLC-40 up before the FH launch is to protect against any anomaly FH has. The company could then still continue launches at SLC-40. An anomaly with FH would likely be exclusive to that rocket and F9's could still be launched.
SLC-40 will be exclusively for Falcon 9 satellite and cargo launches.
LC-39A will be for both Falcon Heavy, Falcon 9, and any Commercial Crew launches.
Vandenberg is for West Coast polar launches. It has the capability for both F9 and FH.
Boca Chica is still a couple years away but it should be used for FH and F9.
LC-39A stil needs some modification for Falcon Heavy though not too much. So after SLC-40 is up then there will be a big focus at LC-39A to get the Commercial Crew modifications done.
After SLC-40 and LC39A are done with all their modifications, I expect we'll finally see some strong focus on Boca Chica to get it up and running. I expect that to take a couple years to pull off since it is being built from scratch.
I suppose we'll eventually hear where SpaceX intends to do ITS but wherever it is will need lots of modification and infrastructure to support it.
Hopefully that explains it.
Grendal
SpaceX Moderator
Jan 31, 2012
5,696
6,863
Iridium just announced confirmation for their NET June 29th launch date. Since the cadence seems to be picking up over the next few months, here are the next 10 launches:
Date? Launch site Orbit Weight Payload Recovery
Apr 30 [11:00 - 13:30 UTC] Falcon 9 LC-39A LEO? ? NROL-76 LZ-1
May 15 [23:20 - 00:10 UTC] Falcon 9 LC-39A GTO 6070 Inmarsat 5-F4 no
May 31 Falcon 9 + Dragon LC-39A LEO (3300) CRS-11 LZ-1
mid Jun Falcon 9 LC-39A GTO 3669 BulgariaSat-1 LZ-1 or ASDS
late Jun Falcon 9 LC-39A GTO ~6000 Intelsat 35e no
Jun 29 Falcon 9 LC-4E PO 860 (x10) Iridium 2 (21-30) JRTI
Jun Falcon 9 LC-39A GTO 5400 SES-11 (EchoStar 105) OCISLY
Jul Falcon 9 LC-39A GTO ~3500 KoreaSat 5A LZ-1 or ASDS
Jul 22 Falcon 9 LC-4E SSO 525 FORMOSAT 5 JRTI
Aug 1 Falcon 9 + Dragon LC-39A LEO (3300) CRS-12 LZ-1
Minimum of 5 booster recoveries with one or two opportunities for a reuse flight.
Edit: Annoying that I can't seem to format this. Sorry about that.
Reactions: GoTslaGo
GoTslaGo
Learning Member
Dec 25, 2015
3,063
4,709
US
Quote:
Date?..................................................Launch site....Orbit.....Weight......Payload....................Recovery
Apr 30 [11:00 - 13:30 UTC] Falcon 9...LC-39A.........LEO?.......?............NROL-76....................LZ-1
May 15 [23:20 - 00:10 UTC] Falcon 9..LC-39A.........GTO......6070........Inmarsat 5-F4.............no
May 31 Falcon 9 + Dragon...................LC-39A.........LEO......(3300)......CRS-11.......................LZ-1
mid Jun Falcon 9..................................LC-39A.........GTO......3669........BulgariaSat-1..............LZ-1 or ASDS
late Jun Falcon 9..................................LC-39A.........GTO......~6000......Intelsat 35e..................no
Jun 29 Falcon 9....................................LC-4E............PO.......860 (x10)..Iridium 2 (21-30).........JRTI
Jun Falcon 9.........................................LC-39A..........GTO.....5400......SES-11(EchoStar 105)..OCISLY
Jul Falcon 9..........................................LC-39A..........GTO....~3500........KoreaSat 5A................LZ-1 or ASDS
Jul 22 Falcon 9.....................................LC-4E............SSO......525..........FORMOSAT 5.............JRTI
Aug 1 Falcon 9 + Dragon.....................,LC-39A..........LEO......(3300)......CRS-12.......................LZ-1
End quote.
So I've found that this site really likes periods (.....) instead of spaces ( ). Hope this helps.
FYI: I put 5 spaces in the brackets after "spaces" and 5 "." after "periods", and we can all see that the site respects the periods, but ignores the spaces.
Reactions: Nikxice and Grendal
Grendal
SpaceX Moderator
Jan 31, 2012
5,696
6,863
End quote.
Ah-ha. Thank you very much. I was so frustrated when it kept removing the spaces that I just gave up and wrote the edit comment. Someone else made a grid to organize a post like this so I spent about 10 minutes trying to figure that out and couldn't do that either. I figured they created the grid elsewhere and inserted it here but was too frustrated to play around with that.
So, thanks again, GTG. Period. :)
Reactions: GoTslaGo
landis
246
349
Pipersville, PA
As I learned recently in another thread, this site also likes html tables.
Just quote a reply (and abort before post) if you want to learn how to do this with TABLE TR TD tags like this:
(Preview is your friend.)
DateLaunch siteOrbitWeightPayloadRecovery
May 1 ?[11:00 - 13:30 UTC] Falcon 9LC-39ALEO??NROL-76LZ-1
May 15 [23:20 - 00:10 UTC] Falcon 9LC-39AGTO6070Inmarsat 5-F4no
May 31 Falcon 9 + DragonLC-39ALEO(3300)CRS-11LZ-1
mid Jun Falcon 9LC-39AGTO3669BulgariaSat-1LZ-1 or ASDS
late Jun Falcon 9LC-39AGTO~6000Intelsat 35eno
Jun 29 Falcon 9LC-4EPO860 (x10)Iridium 2 (21-30)JRTI
Jun Falcon 9LC-39AGTO5400SES-11(EchoStar 105)OCISLY
Jul Falcon 9LC-39AGTO~3500KoreaSat 5ALZ-1 or ASDS
Jul 22 Falcon 9LC-4ESSO525FORMOSAT 5JRTI
Aug 1 Falcon 9 + DragonLC-39ALEO(3300)CRS-12LZ-1
ItsNotAboutTheMoney
10,237
7,330
Maine
If you don't want to do an HTML table you can also use CODE square-tags and everything will be displayed in a non-proportional font so you can use spaces to display the values in columns. CODE's original purpose is to display program code.
Code:
Date                       Launch            site   Orbit Weight    Payload              Recovery
May 1 ?                    Falcon 9          LC-39A LEO?  ?         NROL-76              LZ-1
Jun                        Falcon 9          LC-39A GTO   5400      SES-11(EchoStar 105) OCISLY
GoTslaGo
Learning Member
Dec 25, 2015
3,063
4,709
US
Now that I'm looking at it on an iphone, the ... chart looks funny as well. :(
Looks like @landis and @ItsNotAboutTheMoney have much better solutions! Thanks!
Electroman
6,116
6,173
TX
You guys are all great !!..
SSO - Sun Synchronous Orbit?
PO - Polar Orbit?
I need to go read up on both on what they are and when it is used.
ggr
Expert in Dunning-Kruger Effect!
Mar 24, 2011
6,972
27,477
San Diego, CA
PO - Polar Orbit?
Sun-sync orbit is often used for photographic purposes, because the shadows are minimized and always almost the same. There is seasonal variation but not much daily variation.
Reactions: Mike1080i
