SpaceX Manifest and Launch Cadence
Discussion in 'SpaceX' started by miimura, Apr 7, 2017.
Tags:
Thread Status:
The first post in this thread is a WikiPost, and can be edited by anyone with the appropriate permissions.
  1. SageBrush
    SageBrush REJECT Fascism
    New Mexico
    Please explain
  2. jbcarioca
    jbcarioca Well-Known Member
    A Shortfall of Gravitas – Spaceflight Now
    Logically, I hope, it seemed to me that one primary impediment to faster launch sequence was the practical pace of first sta ge recoveries. Thus, adding this one should allow A higher recovery capacity, therefore probably reducing launch costs and permitting faster placement for refurbishment. Once Mr. Stevens can function as planned for fairing recovery we’ll probably see about two more of those ships too.
    Possibly there will be others as well, since these ships are crucial components of launch cost reduction through reusability.
  3. Grendal
    Grendal SpaceX Moderator
    Santa Fe, New Mexico
    #43 Grendal, Aug 21, 2018
    SpaceX will not likely beat 30 launches for 2018. Somewhere around 24 or 25 seems likely. As of this moment, there are six Block 5 cores completed with only B1051 having the upgraded COPVs that NASA demands for Commercial Crew. The seventh B5 booster is due to appear sometime soon and SpaceX will likely have 10 altogether before the end of the year. I fully expect to see a third launch of the same booster before the end of the year with B1046 being the most likely candidate. One of the upcoming boosters will need to be the B5 FH center core for there to be another FH launch this year (Arabsat).
    There are nine older launched SpaceX boosters sitting around with one (Orbcomm 2) officially and permanently on display at SpaceX's Hawthorne factory. Two more have been given to NASA and Cape Canaveral for future display. That leaves six more just sitting around awaiting use in some form or another.
    cores - spacex
    Edit: It looks like the Commercial Crew delay cut into the number of launches for this year. Likely it will end up at 22. About half of those used previously flown boosters. My guess of 10 Block 5 cores is very likely going to be accurate. They have nine now with 2 1/2 months to go. SpaceX will have launched the same booster for the third time next month, likely the first B5 booster B1046.
  4. Grendal
    SpaceX's Falcon Heavy manifest:
    - Arabsat 6A (NET early 2019)
    - STP-2 (NET 2019)
    - AFSPC-52 (NET September 2020)
    - Ovzon (NET Q4 2020)
    Pending confirmed payloads: - Viasat - Inmarsat
    Michael Baylor on Twitter
  5. Grendal
  6. Grendal
    How about a historical comparison:
  7. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    I can’t view the image in your post.
  8. Grendal
  9. ecarfan
    San Mateo, CA
  10. ecarfan
    San Mateo, CA
    The second graphic I posted shows how rapidly SpaceX has increased its launch cadence in the past 10 years, and how ULA and Arianespace have shrunk, as has Russia. China is increasing its launches.
  11. Grendal
    As of the CRS-18 launch.
  12. Electroman
    Electroman Supporting Member
    TX
    Most confusing graphic.. really hard to understand at the first glance..
  13. ecarfan
    San Mateo, CA
    Maybe, but impressive stats record keeping! I read every line and loved it.
  14. Grendal
    As of this date, SpaceX has a stable of 6 Block 5 F9 boosters to use and reuse. There are also the two B5 side boosters available for a FH but no center core at this time.
    The six current F9 boosters have the following number of launches behind them:
    B1048 - 4
    B1049 - 4
    B1051 - 3 (will launch for the 4th time very soon)
    B1056 - 3
    B1058 - 0 (DM-2 booster)
    B1059 - 1
    The FH boosters have both flown for 2 missions.
  15. mongo
    mongo Well-Known Member
    Michigan
    SpaceX is planning on 38 launches this year, 64 the following two year, and 70 a year after that!
    10 FH a year starting in 2021.
    From recent FAA submittal linked to here:
    nextspaceflight on Twitter
  16. ecarfan
    San Mateo, CA
    Wow. And 10 FH launches a year? That will be mind blowing!
  17. mongo
    Michigan
    Yah, although it may just be the optimistic best case scenario so they don't need approval later.
    Theoretically, Superheavy/ Starship will replace FH launches due to lower cost.
  18. Grendal
    That is weird. SpaceX had 21 launches in 2018, not 15, 2017 was 18 launches, and 6 for 2015.
  19. favo
    favo P3D+ owner
    Durham, NC
    That chart doesn't show Vandenberg AFB launches (2 in 2019, 6 in 2018, 5 in 2017).
    • Helpful x 3
  20. Grendal
    #60 Grendal, Jun 9, 2020
    At this moment SpaceX has only five boosters available for standard launches:
    B1049
    B1051
    B1058
    B1059
    B1060 - spoken for until recovered
    All except for one (B1058 May 30th) will be launched this month June 2020 - weather permitting. The shortest turnaround time for a Block 5 booster has been 2 months. Sadly, the loss of two boosters in landings earlier this year may cause some delays in upcoming Starlink launches.
Thread Status:
