SpaceX Starship SN9 experimental test vehicle
Discussion in 'SpaceX' started by Grendal, Dec 10, 2020.
  1. Grendal
    Grendal SpaceX Moderator
    Santa Fe, New Mexico
    #1 Grendal, Dec 10, 2020
    SpaceX will be rolling out SN9. It is currently scheduled to continue testing a high altitude launch, flip maneuvers, and landing.
    Launch Date: Feb 2
    Launch Window: Late afternoon
    Launch site: Launch Pad Test Stand 2 - Boca Chica, Texas
    Mass: TBD
    Altitude Goal: 10 km
    SpaceX
    SpaceX Starship - Wikipedia
  2. adiggs
    adiggs Active Member
    Portland, OR
    We get to see the belly flop again!
    Now that I've seen the water tower go up, I've started thinking -- where will the people / cargo go when it's time to put real stuff on board?
    I assume that the current 16 story (I think I heard that on Scott Manley's recap) unit isn't the full scale size yet. Presumably the cargo will go into the nose cone, which will in tern need to get bigger.
    I can't help myself - it's going to be awhile before it's actually Starship and not "flying water tower" to me :)
  3. mongo
    mongo Well-Known Member
    Michigan
    It's full size.
    The cargo areas is the nose cone plus 4 of the ring segments (above dome, 5.5 to dome edge). Each ring is 6 feet or so tall.
    • Informative x 2
  4. Grendal
    Here's a speculation on the interior of SN8. You know this wrong in some way because it lacks the header tanks. I also think the actual tanks are larger. Scott Manley described it as 12 stories tall.
    Rocket size comparison:
    I think the size comparison to the Space Shuttle brings it home for Starship:
  5. HVM
    HVM Savolainen
    Finland
    #5 HVM, Dec 11, 2020
  6. bxr140
    bxr140 Active Member
    Bay Area
    That's a serious issue. Real JV level stuff.
    Accepting the possibility/probability of failing in controlled environment--like SN8 lawn darting into the landing pad--is a huge development advantage for SpaceX. Few others in the rocket space are willing to push technical limits to the extreme in that way because of the perception that those kinds of failures are fast and loose, but in reality those are still controlled, engineered situations.
    Having a failure like this one is good old fashioned negligent fast and loose. There's no acceptable reason for this to happen, regardless what the root cause ends up being.
    Very bad show.
  7. adiggs
    Portland, OR
    Hey, nothing to see here. That'll buff right out. And besides, a few door dings gives a vehicle character.
    (Yes, I'm being silly; me, not the situation :D)
  8. Pricee2
    Pricee2 Member
    Snohomish WA USA
    Looks like SN9 had one Margarita to many.;)
  9. Electroman
    Electroman Supporting Member
    TX
    Agreed. This is not acceptable.
    SN8 crash landing is not a failure of anything. It is a datapoint in a controlled test. SN9 pad crashing in the bay is negligence and incompetence of someone.
  10. ICUDoc
    ICUDoc Active Member
    Sydney NSW
    IANARS but I agree with the emotions expressed- SN8 disintegreat- never expected perfection, it was a test. Thought they did wonderfully well.
    SN9 unplanned recline- well, I DID previously have confidence in their ability to keep the pointy bit straight up before launch- sadly, not so much, now. I'm sure Elon will put it right. This whole SpaceX endeavour is so enjoyable to follow :)
  11. Electroman
    TX
    There have been cases (not in SpaceX) where satellites were dropped from the crane during testing, destroying millions of dollar worth of equipment, not to mention years of setback to the program.
  12. adiggs
    Portland, OR
    Makes a drunken test vehicle sound pretty minor
  13. nwdiver
    nwdiver Well-Known Member
    United States
    If you were SN9 would YOU want to leave the hanger after seeing what happened to SN8? ;)
    • Funny x 8
  14. bxr140
    Bay Area
    When quarantine is over, buy me a drink and I'll give you a doozy of a story...
  15. charliepmayer
    charliepmayer Member
    Texas
    Tease! Please continue. We won't tell anyone. I promise.
  16. dkemme
    dkemme Supporting Member
    Greeley, CO
    How about I Venmo two drink equivalent for more info now?
  17. HVM
    HVM Savolainen
    Finland
    SpaceX has slowly lifted SN9 back up, with jacks and beams, giant crane Pluto securing the top.
    It's possible that the stand did not give in but whole SN9 stack tilted. If you check Steve Jurvetson's photos, the stand is weighted down with steel rolls, only with one side. So there was some reason for SN9 to try tilt to the nearest wall, -by weight distribution or just by wind. Aaand too few rolls were used.
    (Correct way to use anti-corona bandana?)
    https://twitter.com/FutureJurvetson/status/1337959718896115712
  18. HVM
    HVM Savolainen
    Finland
    I bet that lashing chains, wooden planks and haphazardly weld steel rolls give bxr140 warm and fuzzy feeling (and any OSHA officials too). Some of the feet seem to have anchor bolts but not all, "it weights ~200 metric tons, where it going to go" but it's also 50 by 9 meter (+ body flaps) sail...
    ; P
  19. HVM
    HVM Savolainen
    Finland
  20. nwdiver
    United States
