Spare lay flat tire
Discussion in 'Model S' started by mcg888, Jul 24, 2015.
Tags:
  1. mcg888
    mcg888 New Member
    Australia
    Hello guys,
    Can you please help me find any lat flat tire for S90D? Any suggestions? I'd like to keep a spare in the Frunk. Thanks.
  2. kuttakamina
    kuttakamina Member
    DC
    I may have misunderstood what "lay flat" means .. but 90D's trunk is too small to hold a fullsize spare. I keep the Tesla emergency tire repair kit in the trunk.
    Disadvantage - if you ever slime fill the tire, you need to buy a new tire.
    Advantage - you can air up the tires at home.
  3. Max*
    Max* Charging
    NoVa
    Like kutta said there is a 0% chance of a spare fitting into the frunk. You'd be lucky to fit a bag there (ok, it's not that small, but on the D's the frunk is a LOT smaller than on the non-Ds)
    It's much easier to keep an air compressor, a pair of pliers, and a tire plug kit in the frunk.
  4. meloccom
    meloccom Moderator Aus/NZ
    Sydney Australia
    #4 meloccom, Jul 24, 2015
    There is already a thread talking about compatible space saver spare tires.
    Compact Space Saver Tire/Wheel Solution
    - edit-
    Just noticed you're getting a D not sure this will fit in the frunk of a dual motor model.
  5. Max*
    Max* Charging
    NoVa
    That's for the non-D cars. I don't see any way to fit a spare tire in a D-car.
  6. mknox
    mknox Well-Known Member
    Toronto, ON
    I'm not sure, but I don't think you can even fit a full size spare into a non-D frunk. I believe someone was able to find a compact spare for another brand of car (BMW?) that fits the Tesla and fits in the frunk. You'd also need some sort of jack and wrench and find a way to fasten it all down so it doesn't rattle around.
  7. dgpcolorado
    dgpcolorado high altitude member
    The Western Slope, Colorado
    What does Tesla do for a spare in countries, such as Australia, that require one?
  8. murphyS85
    murphyS85 Member
    Horsham, PA
    I have a full size 19" spare in my pre-autopilot S85 frunk.
  9. S'toon
    S'toon Knows where his towel is
    AB
    What if someone kept an uninflated tire, and an air compressor?
  10. JST
    JST Active Member
    That wouldn't fit in the frunk of a D, either, since the diameter of a deflated tire is not appreciably smaller than an inflated one.
    There are compact spares that work basically this way (a deflated tire that pops open when you inflate it); Porsche used them on 911s for a long time, and Mercedes still uses them. I couldn't find one with the proper diameter/wheel bolt setup (and I could only find them sold as sets, and they were expensive). Linkster may have done more with this. But even those won't fit in a D frunk.
    If you're concerned, you could carry a compact spare in the rear trunk. There's plenty of space back there. I used to do this in a BMW M3 that had much less trunk space than the Tesla does. Not as elegant, but it does the job.
  11. scottreds2k
    scottreds2k Member
    Silver Spring, MD
    It would be much easier to fit your AAA card in the frunk.
    Kidding aside, I haven't carried a spare tire in my S2000 for the 15 years I've owned it, and I had exactly 1 flat tire. I'd rather not waste the storage space for a spare.
    Porsche 944's also had the odd pre-flattened spare with a compressor.
  12. mknox
    Toronto, ON
    I've had relatively few roadside flats too, but when I did, I could call Roadside Assistance and they would come, change the tire and I may be an hour or so late for work. If I had to have the car flat-bedded to a tire shop or Tesla, I could easily lose the day dealing with a measly flat tire.
    - - - Updated - - -
    Interesting. I could probably throw one of my 19" winter tires (on its own rim) in there... Probably won't, but it might be good "road trip" insurance.
  13. Father Bill
    Father Bill Member
    Brighton, IL
    I too have a 19" Spare in my S85 frunk. I have lost too many tires in the pothole fest that is the Saint Louis, MO area to drive anywhere without one. It is also good road trip insurance when on the road. YMMV
    Peace,
    Father Bill
  14. murphyS85
    murphyS85 Member
    Horsham, PA
    I built a support out of wood for the forward edge of the tire so it wouldn't be resting on the plastic above the frunk emergency release button.
  15. KJennerator
    KJennerator Member
    MA
    We fit a full size spare into my dad's S60, but that's without the front motor.
  16. Dborn
    Dborn Confirmed
    Sydney, Australia
    I have a full size, Tesla supplied, wheel and tyre fully inflated in my frunk. I also keep a breaker bar, torque wrench, floor Jack, and a set of wedges I made out of timber in there. The wheel is upside down which leaves me with a centre well in which to store the jack and wrench. The rest fits around it and in the microwave. Obviously a non D car.
  17. mknox
    Toronto, ON
    Someone in this thread or elsewhere was suggesting that Australia requires that manufacturers provide a spare tire. Is this the case, and when you say Tesla supplied the tire, did they do so as part of the vehicle purchase?
  18. meloccom
    Sydney Australia
    Australian Model S come without a spare tyre, Dborn purchased his separately.
  19. PatD
    PatD Member
    Broomall, PA
    How do they charge for this, out of curiosity? I know roadside assistance is free (In the beginning) but what about the tire itself? And/or can they plug it roadside?
  20. mknox
    Toronto, ON
    Well, I haven't had to do this with the Model S (yet!). The last time was in my Cadillac and I just hit the OnStar button. The service was impressive. They got someone out right away to put on my spare and even called me back and gave me $25 of free OnStar calling minutes because of the "inconvenience". I mean, it wasn't GM's fault I ran over a nail. I dropped the wheel off at my dealer and went back a day or so later and they swapped it back for me all at no cost.
    Prior to that I've called CAA (I have a membership) or just changed the tire myself.
    As far as the Tesla goes with no spare, my understanding is that they have to flat bed the car somewhere. Not sure if they take it to a Tesla Service Center or a tire shop. I didn't buy my tires from Tesla, so I suppose I'd be on the hook for whatever the tire repair/replacement costs are. I don't mind that so much, but I really don't relish the hassle of having to flatbed the car away and losing all that time to dealing with a flat tire.
    I'm leaning towards throwing one of my winter wheels in the frunk, but no jack or tools. At least Roadside could swap it out and I could be on my way.
